Question about Apple iPod nano
Disk Mode Does anyone ever have there IPOD lock up on Disk Mode?
    President:
  • 317 Answers
So are you saying it's stuck in disk mode? To get it out of disk mode you have to do a reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Posted on Feb 26, 2008
Thanks it worked......
Posted on May 29, 2008
Thank you it worked
Posted on Apr 22, 2008
How to disable ipod
Your iPod touch shows a lock symbol on the top of the screen when it's in lock mode. This protects your iPod from being accidentally bumped on or off while you're focused on other things. Getting in and out of lock mode is somewhat intuitive, but can take a couple of tries the first time.
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off.
This helps save battery life if you have it locked while it's asleep.
It prevents your music from turning off if you've put your iPod in your pocket. However.
it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right.
Mar 24, 2013 | Apple iPod touch
It has a locked in the screen
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off. This helps save battery life if you have it locked while it's asleep. It prevents your music from turning off if you've put your iPod in your pocket. However. it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right. Hope this helps.
b>
Jan 22, 2013 | Apple iPod Audio Players & Recorders
Froozen and wont do ANYTHING
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    • utting iPods with a Click Wheel into disk mode
      1. Before placing the iPod into disk mode, you should verify that it is charged.
      2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
      3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
      4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
      5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
      If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
      If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 05, 2010 | Apple iPod nano
When i got done chrging my ipod it froze
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
Resolution If you experience any of the above issues, try the following steps:
Dec 17, 2009 | Apple iPod Photo MP3 Player
Ipod on disk mode. not able to do anything.
This solution for the ipod white screen of death also has how to get out of the disk mode
http://www.zolved.com/synapse/view_content/19067/The_Apple_iPods_White_Screen_of_Death
Oct 19, 2009 | Apple iPod nano
I Have a 3rd gen ipod and its stuck on the lanuage
Try reseting it. If that does not resolve the issue, put it into disc mode and restore again. If these steps do not help please let me know.
Learning how to reset or restart your iPod:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
May 05, 2009 | Apple iPod nano 3rd Generation
My ipod keeps showing me the red x
you have to set it to disk mode in itunes first then you should be able to acssess disk mode
Restore iPod from Disk Mode
  1. Disconnect iPod from your computer.
  2. Manually put iPod into Disk Mode as explained in support document 93651.
  3. Open the latest version of iTunes and connect iPod.
  4. Restore iPod as explained in support document 60983.
Mar 29, 2009 | Apple iPod classic MP3 Player
Unlocking ipod touch
put it in disk mode then restore it...good luck!!  (P.S.- To learn how to put it in disk mode visit apple and search for help on the topic)
Oct 29, 2008 | Apple iPod nano
Ipod nano lock forgot password
First, try to restore using iTunes. If this doesn't work, place your iPod in disk mode (hold the menu and center buttons down togther) and as soon as you see the Apple symbol come up hold the center and play (bottom) buttons down together until you see a check mark (disk mode). It may take a few trys.
Now connect your iPod to your computer. Go to my computer and right click the drive associate with your iPod (for example F: ) and scroll down to FORMAT. THIS IS VERY IMPORTANT - CHOOSE FAT32 and then check the "Quick Format" box. After you do this then use iTunes to Restore your iPods another time.
Jan 31, 2008 | Apple iPod nano
Apple iPod nano Logo
132 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
