Question about Mitsubishi WS-55819 55" Rear Projection Television
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
  • sean benaitis Feb 17, 2010
    the model# ws-55819 i am sure of that. yes photo and step by step instructions for the repair of 2,2 would be very helpful. Thank you.
  • rekey140
    rekey140 Jul 14, 2013
    i don't have the four digit code ,how do i take it off,i got the t.v. off craigslist and the code even interupts certain commercial's
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Posted on Feb 17, 2010
Testimonial: "yes you were right I plugged the tv in tried to turn on shut right down then checked code (menu, input) now 2,2 is the code. thanks"
  • 1 more comment
  • SD Tech
    SD Tech Feb 17, 2010
    If 2,2 one of the two 5 amp fuses (pico fuses) is blown and the convergence chip/s got it.
    Confirm actual model number---I have photos and step by step instructions for this specific repair.
    Total parts cost will be under 30 dollars--I have repaired hundreds for people here.
    SD TECH
  • SD Tech
    I will send the photos first here--the instructions will post in several parts as they are too long to post in one shot.
    SD TECH
  • Elitebodyink Nuttall
    Elitebodyink Nuttall Nov 23, 2013
    the tv will turn on and stay on sometime for weeks, sometimes it turns right off green light blinks 2
I have an mitsubishi medallion hd1080 big screen that wont turn on. I tried unplugging and plugging back, the light will blink but the TV wont turn on. what should I do?
Posted on Jul 28, 2010
SOURCE:
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Inputs randomly stop registering, screen goes blank
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
Dec 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
My t.v. wont turn on. I have a Mitsubishi, Medallion HD 1080. Model ws-65819.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
Jan 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsbishi model ws-65819 HD 1080 medallion, wont turn on
Mitsubishi Medallion Hd1080
Try to access the self diagnosis feature, by pushing the input/device and menu buttons in on the set itself and hold them both in together for 8 seconds to see if the led will blink a two digit code. If it doesnt that means the processor isnt powered so therefore its a standby voltage issue thos are usually easy to track down Try the proceedure to access the diagnosis feature then let me know the results.
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Manual mitsubishi medallion hd1080
MY MEDALLION WILL NOT TURN ON THE GREEN LITE IS GOING ON AND OFF THAT SAYS TIMER ON CAN U TELL ME THE PROBLEM.
Mar 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
2,664 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
