Question about Garmin StreetPilot C330 GPS Receiver
How much power theis product use/
I had a 20 amp fuse blow could you tell me how many amps this one use's or pulls/
  • cba321 May 18, 2008
    HOw do you even open this unit to get to the fuse?
  • Anonymous Mar 07, 2009
    I've had 2 20amp fuses blow in the past 2 months with my Garmin StreetPilot c330 hooked up.
  • 42 Answers
Http://www.garmin.com/manuals/StreetPilotc330_OwnersManual.pdfwww.garmin.com/manuals/StreetPilotc330_OwnersManual.pdf
Posted on Feb 27, 2008
  • KENNY ZIMMERMAN
    KENNY ZIMMERMAN Feb 27, 2008
    IT LOOK LIKE IT ONLY PULLS A COUPLE AMPS
    IF THE LINK WILL NOT WORK LOOK UP THE PRODOCT IN
    www.garmin.com
    good day
    kz
    it should not blow a 20 amp fuse.
Gen set blows fuse
no
a fuse is there to protect the circuit and the genset
check why the de-icer is pulling so many amps as the problem may be in that unit
a 10 amp outlet has a maximum current capacity of 10 amps as that is the current allowable from the gen set and wire capacity
even if you had an outlet with 15 amp rating , it would still be blowing fuses as the 16 amps is above the allowable current draw
you would need a 20 amp outlet ( difficult to get unless it is in a house power board and are normally reserved for hot water systems , stoves and other high current usage units and are normally then not outlets but hard wired in to a circuit breaker
Aug 10, 2016 | Kohler Electrical Supplies
What fuse do i take out to keep the horn from blowing on a 2000 dodge stratus
Simply Take Out 10 amp Fuses One at a Time Until Horn Stops, Repeat With 15-20-25 amp If Necessary But Most Likely 10-20 Amp Fuse
Jun 03, 2015 | 2000 Dodge Stratus
92 geo tracker keeps blowing fuel fuse 15 amp but when I go to a 20 amp it is fine gas tank is haff full of fuel what is my problem
first off each fuse has a name , so what is the correct name, the 92
has 3 EFI fuses, DOME (memory) IG-Coil (ecu and spark) and "FI"
never up the amps ever or burn the wires up. sorry but that is a FACT. the a above data is wrong, this cars pump draws 4amps.
if more its bad, sure if over 15 it blows, but is a bad pump.
all pumps like to do that, they burn up and suck power, like a piggy.
see your fuse here, linked,
this car and ECU nor know for shorted pumps and shorted ECU
the 92 uses these JUNK brand caps, large electrolytic caps.
and they love to short, on all 89 to 95 trackers and sidekicks in usa.
they are marked Rubycon.
so again which fuse?
ill pretend its FI blown
http://www.fixkick.com/power-elect/blows-fuse.html#FI_blows
FI is bottom right, lost the cover? now you have one.
http://www.fixkick.com/Elect-fail-index.html
is engine 8 valve or 16?, they have different EFI , systems.
Im sure its FI, as it runs ECU and pump. so..... and they love to blow.
ok i throw dice for you, land on 8v.
see 8v FI fuse here?
http://www.fixkick.com/ECU/8v-tbi-schematic91to95.jpg
what i do is remove the left rear tail light,lens.
then see the pink pump wires, I measure the pump current
i reads 4 amps, with helper keying on over and over.
see?
now if near 4amps, then the ECU is shortings it CORNER cap.
http://www.fixkick.com/ECU/ECU.html
the caps dry out,inside, leak acid , wreck copper traces
and then the cap shorts, some times , it loves to short on speed bumps. due to vibration, its just a bad 50 cent part
that any tech can change or any HAM radio guy, etc.
with simple soldering tools and skills
do tell engine type G16a or b (a= 8v, and b = 16v) and we can
point to exact part bad.
Jan 29, 2015 | Geo Cars & Trucks
How do I find the fuse panel on LG model LSC269055b refrigerator
I think your model number is actually LSC26905SB
There isn't a fuse panel, per se. If I remember your model correctly, the main board is on the back, so pull your refrigerator out, unplug it, and take off the access cover located about halfway up your refrigerator's back. Look at the fuses on the main board. There is a 20 amp fuse that blows easily (the newer boards have a slower blowing fuse in them, now). Temporarily jumper the 20 amp fuse and then plug your refrigerator back in. If you hear relays clicking and such, that's good. The compressor should start up shortly afterwards and all the lights should be on in your refrigerator.
After you have verified operation, go to Radio Shack, or somewhere similar and get yourself a 20 amp slo-blo (slow blowing) fuse and solder it on top of the old fuse on your main board.
Remember to always unplug your refrigerator when dealing with the main board and power circuits.
Good luck and let me know if you need any more help.
Nov 17, 2014 | LG Refrigerators
Hi I have a C5 2005 turbo Diesel that is blowing
Hi Paul
You have a faulty starter motor,Common fault on the c5 starter sounds ok but is drawing too much power,And blows the 20 amp fuse for ecm
Oct 20, 2013 | 2005 Citroen C5 2.0
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Keeps blowing fuses!!!
HI ..PUT AN AMP METER IN LINE TO SEE WHAT THE AMP IS DRAWING..WHEN IT IS CRANKED UP ..IS 20 AMP WHAT IT CALL FOR ON THE AMP IF SO I WOULD NOT GO ANY HIGHER.....BUT IF YOU HAD JUST USED 20 AS A STARTING POINT FOR AN AMP-AGE...SOMETIMES IT IS BETTER THAT THE FUSES BLOW ONCE IN AWHILE THAN THE AMP...ALSO CHECK FOR A LOOSE GROUND.....GOOD LUCK
Jan 29, 2009 | Planet Audio VX2002 Car Audio Amplifier
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Basslink
make sure ur ground cabke is as large if not larger then ur poweer cable.
Oct 11, 2007 | Infinity BASSLINK Car Subwoofer
Garmin StreetPilot C330 GPS Receiver Logo
57 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
