Question about OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 320 Problem...
I just bought a used Microline 320 Printer and it prints fine, but the only problem is that I have to turn the printer off, then on again, before it will print a page. I have to do this every time I print. I re-installed drivers, re-started my computer, and nothing seems to fix it??
    Welcome Back:
    Visited the website for 2 consecutive days.
Make sure Autoselect is set to ON
Posted on Mar 12, 2009
    Habit-Forming:
  • 40 Answers
I think you maybe using the wrong driver.Printout the menu if you are set for IBM than choose the "IBM Proprinter" driver in windows.Hope this helps.
Dezzi
Posted on Nov 29, 2008
How do i get my OKI microline 320 to print darker. I added a new cartridge and it still prints light
have you tried cleaning printhead easy two screw comes out ribbon cable off soak in isopropenol will clean jets out
Oct 08, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Hi oki 320 turbo printer started to print very light ,i want to change the ink ,but i do not know where to put the ink ,please help
There is now ink in the machine. You just have to replace the print ribbon. This is the small black box that is mounted to the printhead.
Jul 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I have a OKI Microline 320 printer.
Your printer has a damaged mainboard. Very sorry, for yours is a very good unit. the replacement model is the Oki ML-420, which comes with a 3-year warranty.
Be blessed.
Oct 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Oct 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo printer
Did you check your print queue? May be there is an error in there waiting for you to instruct it.
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
368 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
