Question about Encore Easy PC Backup (24105) for PC
Error 507 I now receive Error # 507 (writing the backup archive). I have disabled the anti virus program and anything else that might conflict but still get the same error. Any suggestions would be appreciated.
    Scholar:
  • 80 Answers
Hi
The Error 507 is generally a result of an I/O problem with the target device.
Some possible causes of this error are:
  • Target device is full.
  • a "bad spot" on a CD-RW disk (possibly cured with a reformat).
  • a loss of connection on a network disk (especially with wireless networks).
  • a firewall blocking access to a networked backup device
  • out of date driver software for a CD writer.
  • hardware problems with the a disk, disk controller or network.
The error will also occur if attempting to save a backup file greater than 4gb on a disk formatted with the FAT32 file system. You must use the NTFS disk format if files are larger than 4gb. Alternately, all of our backup programs allow you to save the backup file in smaller 'chunks' to avoid the 4gb limit of FAT32.
Posted on Feb 27, 2008
How to fix error codes
First have you removed the previous Anti Virus installed on your computer? Often you must use the Anti Virus Removal Tool found on the Anti Virus Manufacturer's website that you are replacing with AVG. Two Anti Virus programs on a machine will conflict. If you only used the Windows Uninstaller most likely it's not completely removed.
Apr 03, 2013 | Acer Computers & Internet
My computer wont load new programmes unless i disable my anti virus
I would suggest to get rid of Norton via control panel - Remove programs reboot computer and then install Free AVG. anti virus program seems more flexible with current software then the previous minimizing fire wall conflicts and issues.May get ti here or Cnet.com
http://www.avg.com/us-en/trustav_bt_ppc?ctype=ppc&utm_source=google&utm_medium=cpc&utm_term=free%20avg&utm_campaign=US%20AVG%20Free&gclid=CPO635vKxLICFQQ3nAodA1sACw
Sep 20, 2012 | Acer Aspire One A150-1006 Notebook
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Trend microsoft will not remove my virus. Is
http://free.avg.com/ww-en/download-avg-anti-virus-free
Here's a link to one of the better anti-virus programs. I have used this one for several years and it does the job. You may have to uninstall Trend Micro and then install A.V.G. as most anti-virus programs will conflict with each other.
Jul 11, 2010 | Trend Micro Internet Security 2008 3-User...
When i going to write any thing in pen drive it shows write protected For that i need a solution
Any user use USB anti virus program?
If yes try to this,
uncheck "Disable writing of any usb devices".
Dont use this software? any one (maybe your friends use this software and disable write protection in your pendrive ) contact your friends.
OR
download USB anti virus program from google search, and try to uncheck disable writing option.
Mar 18, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
I have transcend 8gb pen drive which is write protected ..how to remove it
If yes try to this,
OR
Mar 17, 2010 | Transcend (589307) Media
How To remove white protection from pen drive
If yes try to this,
OR
Mar 15, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pendrive is write protected . i want to foprmat it now. please help me.
Longshot but you could try plugging it in and right clicking click properties and then look for the box with write protect uncheck said box hit apply and bob's your uncle Good luck
Mar 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Receive error while trying to update antivirus
Dont bother. There are so many free
programs out there. Read on.
Go to www.trendmicro.com, and do the free scan Trend Micro's House Call virus, spyware and malware scanner and cleaner. http://housecall.trendmicro.com
If you have anything, remove them. Helpful Free Software below Read On.
FREE SPYWARE
Download Spybot Search & Destroy. Restart computer, then run Spybot to see what spyware comes up, AND DELET IT.
FYI---Virus Protection-- 2 programs of virus protection will conflict with each other and will actually cancel out the protection. SO just download one.
Running Spybot Search & Destroy with EITHER Avast or Avg (great Free virus protection programs ) will keep a computer in good working condition. FREE
Avira AntiVir – Free Anti-Virus Protection
http://www.free-av.com/
FROM MICROSOFT 2009 -Free --Security Essentials
http://www.microsoft.com
Pop up Blocker- free
www.panicware.com
Spybot - Search & Destroy 1.5.2 -FREE SPYWARE
http://www.download.com/Spybot-Search-De…
Avast- FREE ANTI VIRUS PROGRAM
http://www.avast.com/eng/home-registrati…
AVG- FREE SPYWARE PROGRAM
http://www.free.avg.com
Ccleaner- FREE
http://www.download.com/3120-20_4.html?q…
Malware- FREE
http://www.malwarebytes.org/.
$ *** KASPERSKY ***
http://www.kaspersky.com
There are alot of $ anti-virus and Internet security programs out there-ie: Norton, McAfee, Panda, Bitdefender. If you would like to pay $ then get ***Kaspersky***-- 2010 , I feel that is the best for your money.
REMEMBER TO KEEP UP THE DAILY MAINTENANCE ON ALL OF YOUR COMPUTERS.!
If all else fails, then do a Reformat. You will loose everything, so do a Back-up.
Good Luck.
Dec 13, 2009 | Symantec EndPoint Protection 11.0 (250-499...
When I try to install my 8300 series Lexmark printer to my compaq presario with a windows vista operating system I get an error message that sais I have to disable my anti-virus software before I continue....
FIRST you go to your ANTI-VIRUS program , go to PROPERTIES , there your gonna see a window and where it says ANTI VIRUS enable or on , just click to disable it , i cant be more helpful cause I dont have the brand of your anti virus software , hope this helps AJ
May 14, 2008 | Office Equipment & Supplies
Encore Easy PC Backup (24105) for PC Logo
104 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
