Off again on again ?
My parents have a 60" hdtv projection tv. it is fantastic when it is working properly. it seems to be turning itself on and off every couple of minutes and it stays off for almost two minutes at a time, almost like it is trying to cool itself off or something. HELP !!!!!!
  • 8,617 Answers
What is the model number of the set? Need that info to even begin to help. If its an RCA or phillips/ magnavox please include the chassis number.
Posted on Feb 26, 2008
My sony kdf-60xs955 rear projection tv has started to turn itself off, then on again frequently
This is symptom of weak lamp that has reached end of its working hours life, replace lamp in tv to fix the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Oct 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a sony tv, model number KDF60WF655... i turn the tv on and it turns on for about 1 min then turns off, the green light flashes several times then turns itself on again. the process keeps repeating...
Replace lamp in tv as this symptom shows existing lamp is near to end of its working hours life span and need to be replaced.
Lamp replacement procedure is easy and would be written in user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony rear projection tv picture going on and off
change the lamp is is too weak to operate properly.
Sep 20, 2009 | Sony KDS-60A2000 60" HDTV
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hitachi 60v500a projection turns itself off
i have the same problem, did you ever get an answer?
May 31, 2009 | Hitachi 60V500 60" Rear Projection...
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Resetting the parental controls
I can help you unlock your Mitsubishi HDTV VChip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Feb 27, 2009 | Mitsubishi VS-60611 60" Rear Projection...
Screen is dead
TV screen dead symptom..I need info about Sound, and standby light at TV front. Is there sound comes from TV? does standby light lit when switch on TV?
Aug 15, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture behind a square
The problem is the close caption turn it off again and when the square leave turn the set off.
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
