Question about Sony DSR-25 Mini DV VCR
DSR 25 Hi for some reason, out of no where, my deck started giving me this error message once a tape is loaded.  C3123 otherwise time code is at 000000 as should be when deck is turned on.  any ideas? no fix on this end, can I send it in? why isnt it listed on the sony site (!)
  • natashalk Feb 26, 2008
    ERROR message c3123
    ideas?
    Champion:
  • 221 Answers
C:31:23 on a DSR-25 indicates a supply reel problem, most likely caused by a defective cassette housing. Best repair solution is to send it to an authorized Sony repair center.
Posted on Jun 16, 2008
  • 53 Answers
This error can be solve if u have a cleaning cloth and Cleaning fluid but for this u have to open,MECHANISM DECK ASSEMBLY n clean it manually but u have to roted it clockwise
Posted on Jan 16, 2009
Please i need to post a problem, is it for free or do i have to pay for that, i rented a dv-recorder DSR-25 and it counts daily!! carole
Posted on Aug 23, 2008
Hi there I am getting code c31-23 can you please
This is one of the most common problems on sony camcorders. It is caused by the loosening or loss of the rubber roller inside the tape drive mechanism. Try tapping the top of the cam when the tape is inside. If this doesnt work, open the tape deck and look inside to see if you can spot a single rubber roller inside. If not, then the roller has worked itself loose or gone AWOL missing..:(( However, fear not...the solution for this is to go to an office supply store and obtain one of those compressed air cans used for dusting off keyboards and such. Amazingly, the plastic tip on the compressed air can (where the air comes out) can be used as a replacement for this rubber roller. It fits the metal spindle that formerly held the roller perfectly and allows the cam to function without the rubber roller and without the dreaded C31:23 "your camera is dead and useless and will no longer function" evil Sony message... Check out this link for a discussion of this problem: http://wvstephens.blogspot.com/2008/05/sony-handycam-c3123-3123-error-easy-fix.html
Jul 28, 2010 | Sony Handycam DCR-TRV140E Digital...
Error code 09-028
Servo and tape path system error.
0 : Mode cannot be identified, or mode identification is
not necessary.
2 : Threading motor/FG/sensor
8 : Abnormal current detected.
If it’s not just a simple tape jam, then you have a problem with the loading mechanism. The best solution is to take the deck to a service center.
Mar 22, 2010 | Sony DSR-1500 Mini DV VCR
How do you use free run on a DSR-25 Sony Deck?
Read chapter 3 (time code) of your users manual. It outlines the settings for using time code; "free run" means that the time code advances all the time, not just during recording.
Feb 24, 2010 | Sony DSR-25 Mini DV VCR
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
Dec 27, 2009 | Sony DSR-25 Mini DV VCR
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Jul 24, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Sony DSR-80 DVcam - Cartrdge loading mechanism fouled...
The part number for the cassette assembly is A8312671F and it is around 500.00 NOT 200.00 as quoted in the article, and this price comes from the store that is reccommended in the article.
The service manual with the part numbers and prices is 9-977-696-22.
May 01, 2009 | Sony DSR-80 DV/Mini DV VCR
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Oct 17, 2007 | Sony DSR-45 Mini DV VCR
Sony DSR-11 Will Not Recognize Timecode
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly. Try this link first it helped me: Remember follow the instructions ezactly: http://forums.creativecow.net/readpost/35/856108
Sep 11, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-25 Mini DV VCR Logo
756 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
