Question about Tefal Avante Deluxe 4 Slice Toaster
Tfal 2-slice toaster repair
I had a tfal 2-slice toaster and it works fine until yesterday. This morning I tried to toast the bread and the handle will not click to lock it when I push it down. If I hold it down without release it, only the inner side wires turn on, not the outer sides. When I tried to press the "Bagel" button, it will not lite up either. Please help me to fix it. I really like this toaster. Thanks for any expert who can give me some advice.
  • 3 Answers
Look inside your toaster. there must be something inside it turn it down and see if something comes out.. if nothing is inside then try to see if the cord that you switched on is not broken. if you see a liitle bit scratch mark on it- switch off. You can get a electric shock. it is your favorite toaster so try to consult a electricion to fix the cord for you.
Posted on Feb 27, 2008
Download instruction manuals
Here is the TFal home page listing everything about your appliance. If you scroll down to the bottom of the page they have a downloadable pdf copy of the full owners manual.
www.tefal.co.uk/Breakfast/Toasters/Toast-N'-Egg/p/1500576611
Aug 04, 2014 | Tefal Toast N Egg Tt550015 Toaster 2 Slice...
Black & Decker Toaster, model 3550: Pressing the handle down to lower the bread and start the toasting doesn't lock in place anymore. The toaster will toast, but you have to hold the handle down so...
The fact that pressing down the lever fails, means the toaster contact will not function and can not be repaired. Since a two slice toaster is only $15 at Target, why bother fixing a toaster?
Feb 20, 2018 | Black & Decker Toast-It-All Plus T3550...
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Black and /decker toaster model T3550. The outside elements work but the middle ones do not. so only one side of the bread is toaster.And the handle must be held down the whole time to toast
The heating element wire is really thin and there is a great posssibilty of breakage. There is also a spring switch in which the lever locks when toasting. needs replacement.
May 11, 2009 | Black & Decker Toast-It-All Plus T3550...
Back ti Basics toaster the Egg portion does not get hot
Call the company. They will send you a new toaster -- at least they did for my neighbor.
May 10, 2009 | Back to Basics TEM-500 Egg & Muffin...
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
Only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Rdgs
alan
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Tefal Avante Deluxe 4 Slice Toaster Logo
1,310 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
