Question about Canon FAX-JX200
Auto Print is set to OFF and I cant get it to turn to ON
  • 4 more comments
  • Anonymous Apr 17, 2008
    My fax -jx300 has an "auto print off" message in the display and I had tried to fix it changing the settings, but is not working out. Are jx300 and jx200 close, so probably the same troubleshooting will work?
  • Anonymous May 28, 2008
    same problem auto print is set to off and l can't get to to change to on.
    cannot find a reference to it in the manaul
  • Anonymous Jun 10, 2008
    auto print is switched off tried unpluggin machine pressed all buttons only had machine for a few months ready to chuck in bin already.
  • dirwin156 Jun 20, 2008
    i have the same problem help i need to be able to receive faxes now
  • Anonymous Apr 20, 2009
    have the same prob
  • ituza Apr 20, 2009
    how do i turn on auto print
  • 318 Answers
If you press and hold the power on/off button the fax will switch between on and off.If you press the on/off button once for less than 2 seconds it switch between auto print on or off
Posted on Mar 13, 2009
I got same problem..how to solve it?plz help me..
Posted on Jun 11, 2008
  • silvaind1sia Feb 23, 2011
    When show AUTOPRINT OFF, press POWER button 1 time, when show TIME and FaxTel
    AUTOMATICALLY PRINT ON
Thank you, I also had the same problem.
Posted on Apr 15, 2008
The solution given works fine! Tks to Rockyandpolo!
Posted on Mar 27, 2008
Tap the on/off button once.
Posted on Mar 25, 2008
Dear Sir
I just try to make the auto print on, can you please help me on that.
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Mar 31, 2011 | Office Equipment & Supplies
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Envelope printing
Go to custom setting, paper size setting for by pass tray, use custom measurement,input the size of the envelopes ( in X Y mode ). When you print, go to the properties and change the paper tray select from auto to by pass tray.
Good luck.
Mar 11, 2009 | Sharp MX-2300N Color Copier
It keeps reading AUTO PRINT OFF
All you have to do is to switch between auto print off and auto print on.You do that by pressing the on /off button once and then it switch between settings,if you hold down the on /off buton it switchs off.By pressing the button once less than a second it will switch between auto print on or off.
Mar 03, 2009 | Canon Office Equipment & Supplies
I have a Canon Fax-Jx300 and it keeps saying "Rec'd in Memory"
Normally on this machine the auto print is set to off,press the on /off button ones untill it shows auto print on.
Feb 18, 2009 | Canon FAX-JX200
I have a canon fax jx500
Turn auto print on by pressing the on/off button once.If you hold down the on/off button the macine switches off,if you press it once it switch beteen auto print on or off.At first I was also confused by this setting.
Feb 12, 2009 | Canon FAX-JX200
Auto Print off...
Just press your on/off button once,then it will set to auto print.If you keep the on /off button press in for a few seconds it will shut down.By pressing it once it switch between auto print on and off.
I agree this is a funny setting on this model.
Feb 03, 2009 | Canon FAX-JX200
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Adding xerox workcentre 24 driver to new computer
If you press the machine status button.
Print reports
Common Settings. It will include the printer settings.
IP address, printer name etc. I think that information is on page 3.
But you can print those settings easily.
If you need to change them.
Log into the machine with the login or access button, the either 1111 or 11111, will access the tools you need to set up the network.
Make sure you set the IP for manual, not auto, and also turn OFF the IP filter.
If the printer is set to DCHP and auto, it will change the IP on you every time you POPO.
Dec 05, 2007 | Xerox WorkCentre M-24 Color Copier
Canon FAX-JX200 Logo
540 people viewed this question
old marine
old marine
