Old 4 track studio
I have an old TEAC 144 4 track studio. I have not used it for a number of years and although it plays back the sliders crackle badly as if they are contaminated with dust. Is there an easy fix?
    Novelist:
  • 155 Answers
Yes, there is a very easy fix! It is probably just collected dust and crud in the sliders causing the problem.
Get some electrical contact cleaner (available at places like RS, Maplin etc.), stick the nozzle down into the slider slot and give a short squirt. Quickly slide the fader up and down for about 10-15 seconds and this should cure the problem.
You may even be able to get away without using contact cleaner - Sometime just repeated movement of the faders is enough to do the trick.
Matt
Posted on Feb 26, 2008
Why does the cd player not play?
If your shelf system is more than, say, 5 years old the symptoms you describe indicate that the player mechanism may be worn out.
Jul 05, 2014 | RCA RS2635 CD Shelf System
Music playing backwards
Well, not being there to try some diagnostics, there can be a number of reason that the tape plays backwards at times. One reason is that the tapes are 4 channel discrete tape requiring a 4 track 4 channel deck- this would mean track 2,4 are recorded in the forward direction. A Stereo (2 channel 4 track deck) play tracks 2,4 in the opposite direction. That is why you turn the tape over on some decks. Other possibilities could be tape path skew, that reverse relay is NOT changing the head that "listens: to the tape and that is just the start of what it could be. When a new person starts to use a deck of such age- it can be correct to assume that the deck is not working in some respect. A Tape deck Technician such as myself would know how to determine if the deck was working correct or not and know and have parts to correct it. I worked in the Factory Service in Chicago for Teac and actually have one coming into my shop in the near future. After 40 years of working on these I am still at it. I am sorry there may not be an easy answer to this.
Aug 01, 2012 | Teac Audio Players & Recorders
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Jul 27, 2009 | Dell Studio 1737 Laptop
CD PLayer no longer recognising CD RW discs
Try cleaning the discs with straight swipes, with a dry cloth, like your shirt, starting from the center and swiping outward.
Mar 01, 2009 | Sharp CD-XP5500 CD Shelf System
Cd-player (recordable) stops at about track 4 on every CD I play
i,
Based on your post it would seem that the lens get stuck when moving along the slider at about the same position. You can try opening the unit and performing a manual clean and re-application of any thin lubricant. Additionally you can use a can of compressed air to blow accumulated dust and foreign debris inside the unit. The slider would be the small rod encircled in yellow dotted lines.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 28, 2008 | Audio Players & Recorders
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Cannot play newly recorded cd's on any of our home audio systems, auto track or finalize.
UNFORtunately ive seen this many times, some systems only play originals and not recorded ones do to technology changes,
Jan 21, 2008 | Teac GF-350 CD Shelf System
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
DVD Player will not play 20th Century FOX disks
The Panasonic is not "region restricted". This is a security safeguard by studios to keep people from region 1 from using region 3 content. Some material is released in other countries first and later in others. This keeps other regions from using the content from other parts of the world before it is relaesed by the studio there. Your Zenith is not a region free player and the Panasonic is. There is sometimes hacks on Videohelp.com for DVD players to be set to "region free" but not all DVD players are built with it. SONY is another non-hackable DVD player.
Jun 09, 2007 | Zenith DVB412 DVD Player
62 people viewed this question
 Grubhead
Grubhead
