Question about Kenmore 13783 / 13785 Stainless Steel Dishwasher
Kenmore Ultra Wash Dishwasher - 665 - 13783
Hello, our 'ultra' quiet dishwasher is now starting to make a humming noise during the wash cycles. Ther is nothing in the wash module so I have no idea what this could be.
Thanks!!
  • 1 more comment
  • okrocks Feb 17, 2009
    my easher is not spraying on top rack or bottom .
  • David Kassin
    David Kassin Apr 24, 2013
    the filter is clogged where the water goes into the pump. It is usually a screen type ans easily cleaned. Remove the bottom sprayer to access it.
  • Anonymous Mar 23, 2014
    Amana dishwasher when washing is noisy and humming noise. Just started about a week ago.
  • 575 Answers
The filter is clogged where the water goes into the pump. It is usually a screen type and easily cleaned. Remove the bottom sprayer to access it.
Posted on Apr 24, 2013
Dcvxzcxzcxzczxc
Posted on Feb 26, 2008
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash 665.16761690
If it is not overfilling, and then leaking, the whirring noise can be a defective water inlet valve, that stays stuck on open, see here : It's overfilling
If it is not overfilling, the two problems may be unrelated, and the noise can be froma foreign object inside the object trap.
See here about leaks and noise
It's noisy
It leaks
Oct 08, 2008 | Kenmore 16919 Built-in Dishwasher
Dishwashers Logo
2,304 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
