Are you looking for instructions how to replace the stat, where you can get one or who can do it for you?
With either question I would need to know the full model/serial number.
If it was made before 2001 it will have an electric-mechanical stat which to my knowledge may no-longer be available. The electronic stat used 2001 to 2007/8 is still available as well as an upgrade kit to replace the old style. You can call the factory at 800-223-3900 and ask for customer service. Ask for Tim Malloy or Ron Peterson. They will know if they still have the old style stat (easier to replace and cheaper) or if you require the SSAC control or the upgrade kit. Make sure you have the full model/serial number when you call. If you cannot locate the serial number reply back and I'll give you guidance how to determine which control you have.
The factory can also refer you to a servicer in your area. If you need to do it yourself, reply back with what control you have and what you purchased and I'll help you get it installed correctly. Good-luck, Subdriver
My serial number is gone, so I'd appreciate any guidance on determining which control I need. Marvel wIne cooler is currently not running.
24" black, standalone, 6 shelves, manuf date of 2004.
Matt, if the unit was manufactured in 2004 (and does not have a digital display), it has the SSAC control and most likely has a bad thermistor.
