Question about HP LaserJet 3050 All-In-One Printer
Error 344- Fax Function
I have been unable to send faxes to different numbers for months now. I keep getting Error 344. It always sounds like HP 3050 is able to go as far as establishing the connection and then it fails.
Please help. I need this for my business and can't afford to keep running out to a fax/copy place when I should be doing this from home.
  • 5 more comments
  • Anonymous Jul 17, 2008
    I have had the same problem fax error 344 and it appears to connect but it does not go thru. help. Lisa
  • Jason Bailey
    Jason Bailey Jul 21, 2008
    Comm Error 344 is: (Note that this is on the receivers end)
    The remote machine has failed to
    respond to a fax command from the
    product because the connection is
    interrupted.
    The remote user has pressed the
    Stop button while the remote machine
    was receiving.
    Under rare conditions, incompatibility
    between the two machines can cause
    the remote machine to simply
    abandon the call.
    This website will show you what the error codes are.
    http://h20000.www2.hp.com/bizsupport/Tec...
  • hnjzgs Aug 31, 2008
    pls
  • Anonymous Nov 24, 2008
    I have the same recurring problem with the HPL7680 all in one fax.
    Any suggestions?
    Thanks,
  • Anonymous Feb 10, 2009
    I get fax error 344
  • peri1 Feb 13, 2009
    my printer is hp5600 all in one and i have the same problem, what to do ? need urgent to send fax.....
    peri1@zahav.net.il
  • georgiaadamo
    georgiaadamo Nov 23, 2012
    To fix the problem fo to control panel, network and internet then internet options then connections then click on lan settings make sure both automatic detect settings and configuration scripts BOTH must NOT be CHECKED. then click okay and reload page.
The remote machine has failed to respond to a fax command from the product because the connection is interrupted.
The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
Posted on Jul 21, 2008
Set fax quality to standard (instead of fine or photo) and make sure the paper format is compatible with the receiving end (Europe > A4, UK and US > legal)
Posted on Dec 05, 2008
HP7410 ALL IN ONE
Posted on Jul 07, 2008
Disconnect your answering machine can help if it is on the same line. this has worked for me before, but NOT today! disconnect any slicers. not sure if that also means turn off computer if dsl. maybe it worked form e before cuz the computer was off. doesnt happen that it is off often, but mayeb. it's what i am going to try next.
Posted on Oct 27, 2009
  • phippians4v8 Sep 14, 2010
    Interpreting Error Codes in Fax Communication Error or Fax History Reports.
    A fax communication error report or fax history report might contain error codes to help you diagnose fax issues. You can find the error code definitions and solutions in the tables at the end of this document. http://h10025.www1.hp.com/ewfrf/wc/docum...
2 Suggested Answers
SOURCE: Error 344- Fax Function
fax dials out, but after attempts states no answer.
Posted on May 16, 2008
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
Error 386
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 23, 2014 | HP Officejet 6600 e-All-in-One -...
Hp laserjet 3050 has comp error 413, cannot receive fax
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
Also, here is a link for every error code your fax machine could ever display:http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&dlc=en&docname=buu02549&lc=en#Error396
I hope this helps and thanks for using Fixya! ** If you found this helpful, please leave a great rating so others may benefit from this answer too! **
Sep 23, 2011 | HP LaserJet 3050 All-In-One Printer
I have been unable to send faxes to different numbers for months now. I keep getting Error 344. It always sounds like HP 3050 is able to go as far as establishing the connection and then it fails. Please...
Faxing
  1. Turn Off JBig compression.
  2. Move the fax to another location. It may be that they have noise on the line, an alarm, etc.
  3. Turn ECM Off , turn Off V.34 and set the baud rate to 9,600 or lower.
  4. Ensure fax firmware version is at the latest.
  5. Ensure firmware version for fax matches device firmware.
  6. Ensure that the device is using an analog line and phone cable that came with unit.
  7. Reset fax to factory defaults; configure just the basic settings needed to operate (country code, company name, and fax number).
  8. Reseat fax modem in formatter (or Xircom card if legacy MFP).
  9. Try a disk init. (Contact your regions HP Customer Care Center for these steps)
Aug 03, 2010 | HP LaserJet 3050 All-In-One Printer
I get the error 344 message continuously to this one number i'm trying to fax to. i can fax to any other number, but this one # almost always produces this error 344?
Then the problem is most definately on the fax you're trying to send to, and not on your machine. If it works to all other numbers but not to that specific one, then you can shift the blame to the other guy.
Jul 28, 2010 | Office Equipment & Supplies
Fax error 344 - HP officejet 4255 all-in-one
fax error is remote machine not responding to your fax.the other fax has stopped communicating.this is a comms error.
Jun 29, 2009 | HP LaserJet 3050 All-In-One Printer
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
SENDING A FAX TO MULTIPLE RECIPIENTS AT ONE TIME
Type in the first fax number, then hit the Enter key (the check mark), then type in the next number, hit the Enter key, and so on until you've gotten all of your numbers entered. Then hit Start Fax.
Feb 25, 2009 | HP LaserJet 3050 All-In-One Printer
Fax
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Solutions:
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Try to connect the phone line from the phone oulet directly to the line one connection of the machine.
May 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP LaserJet 3050 All-In-One Printer Logo
17,300 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
