Back to:
Tags:
Sewing Machines
Generic problem for all Sewing Machines
Riccar sewing machine 8500 (by 2 users)
posted by turrie on Feb 26, 2008
I just inherited an older sewing machine. Riccar 8500. It will not pick up the bobbin threadt. It works great otherwise. Have a owner manual for model 8400 that I downloaded. Couldn"t find one for the 8500 series. Is there a trick that I am not doing?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Jackeemac, posted on May 21, 2008
I have an older sewing machine that i am starting my grandaughter out on.it is a Riccar superLite. It will not pick up the bobbin thread and it pulls the material down into the feed dog. I have taken it apart and cleaned and oiled it. I do not have an owners manual.
I have - check the threading - changed thread (upper and bobbin)- replaced needle- Is there anything else i can do.
Solution #1
posted on Sep 13, 2008
Not Rated (0)
paris75004
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I don't know if this will help or not, but here is a website where you can download a manual for any of the Riccar products: http://www.riccar.com/help/manuals/
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on riccar sewing machine 8500:
I don't want to Accept this solution
Solution #2
posted on Feb 27, 2008
Not Rated (0)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1288 votes
Providing you have the machine threaded correctly and providing you have a new needle in the correct way round it should pick up the thread, if it does not then you need to retime the machine and if you e-mail me and remind me of your problem I will attach timing instructions drivewithken@blueyonder.co.uk
Thank You!
Can you Help with these Sewing Machines problems?
Juki MO-655 Mechanical Sewing Machine
The stitches look great then there are a few with bobbin...
Sewing Machines
All of a sudden my machine began doing a burst of reverse...
Sewing Machines
I am currently trying to fix mums old Janome XL-II...
PfaFF Creative 7570
problem with pfaff 213 the bobbin was jammed and I had to...
White Sewing 2200 Multi-Tasker
I only can stitch a straight stitch and even then it has...
Loading problems.
Repair Service
Find Sewing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
