Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia 747 won't come on
One day I turned the tv off, next day no power not even blue light. But red light in back of set lights up.....any ideas?
  • Anonymous Aug 17, 2008
    i have a 47inch 747i that wont come on either, its not even a month old!!! turned it on one day, and only saw a no signal at the bottom of screen even though everything was hooked up....turned it off and back on, now it wont even come on. the red lights are on in the back, and the standby light is on, seems like the lighting source went bad...wtf
  • Anonymous Mar 12, 2014
    my 747 olevia tv wont turn on it started out the volume shuttin off on its own for a week then it finally shut itself off and wont turn back on . the blue lite on the front kicks on and off and a loud pop noise when i turn the tv on - shelly
I had the same problem with a 437. It just shut off one day and I could never turn it back on again. I called Syntax Brillian and they told me the mother board was probably shot. They sent me a new TV and took the damaged one back.
Posted on Feb 27, 2008
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
Olevia 537-b11, blue light won't come, even when power cord is replaced. Please help!!!!
Since you've already replaced the power cord and still the led light won't came on, this is an indication that the power supply board of your unit is dead. If it is not under warranty period(if so, avail it because the manufacturer will fix it for free) open the back cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with the same current(ampere) ratings and then try to turn on the TV. If the replacement fuse blew again, this is an indication of more serious problem on that board. If the replacement fuse didn't resolve the issue, other parts on that board gone to malfunction as well. If this is the case, I would advice you to replaced the entire board for your convenient. The cost will almost the same rather than troubleshoot it. Check the actual part no of your board and check this LINK.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Sep 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I have an Olevia 242tfhd television that just stopped working. The blue light was on and when I pressed it- it wouldn't turn on and the blue light went off. I unplugged it for a day and when I plugged it...
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Dec 15, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My olevia 42 in power doesnot come on. blue light was on when I pushed power to turn on tv. Blue light went out but tv did not come on. Blue light didn't not come back on. Television was working good. I...
You may be aware that Olevia is bankrupt and apparently Emerson bought the leftovers and is offering service but no parts sales.
I found this thread discussing antoher model's various problems but I believe your power supply has likely failed.
Olevia thread
If it is the type of failure related to the switched-mode power supply, these can be repaired by a properly equipped tech; I've done hundreds of them while still in business (which I am no longer).
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Olevia Lt32hve set won't come on, blue light is on
make sure your tv is on the right input. Some lcd tvs will lose power and default to digital tv input instead of the analog input or composite input used for cable/satellite receivers or even dvd players
Aug 15, 2009 | Televison & Video
Went on vacation came home Olevia LT20HVK wont turn on red light flashing on power button help''I cant find my owners manual and cant find one online Thank You for any Help
When the red light flashes its a indication that the main-board or the power supply is having some problems..could happen with power outages or power spikes.. this only means the main-board or power supply will have to be repair or replace.. One last thing you want to try is leaving the television overnight unplug from the power and then plug it back in the next day.. if it still reacts the same then the tv has to be service.
Since the Manuf. of olevia is out of buss.. there is a 3rd party service center called Amergence Technology Inc. that is able to service olevia TV's.. there number is 866-965-3842 im sure they are able to give you a repair quote on it...
Apr 04, 2009 | Syntax OLEVIA LT20HV 20 in. LCD Television
Flashing green and red light
Sounds like a power suppply problem. Not something that the novice can repair besides trying the usual unplugging and plugging back in.
Apr 18, 2007 | Syntax Olevia 50" Rear Projection...
Olevia LT37HVS 37 in. LCD HDTV Logo
176 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
