How do i install a security code on my wireless modem and router?
    Genius:
  • 3,587 Answers
Each one is a little different. usually, you log into a screen, after connection, that is unique. Most of them use this one.
102.168.0.1 or some variant.
get the model and maker, go to their website, and usually there's a users manual, or FAQ to use.
check your computer's warranty here FREE
Posted on Feb 26, 2008
I have a belkin router but i cant find the security code for it to use it on a different computer
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Sep 05, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
I wanna protect my connection from outside users i dont know how to protect it !! please help me out!
You listed your problem ubder: modems. A modem you do not need to protect further. You can only use the connection by hooking up a cable to it. If you have a wireless router connected to your modem that should be secured. You do this by entering a security code in the setup of the router. just enter the router's IP address in your web browser, log in to it,go to the security tab under wireless setup and enter a security code. (write it down because you will need it to connect wireless). You can not connect to it without this code. This way your wireless connection is secured and can not be used by outsiders.
Feb 10, 2011 | Computers & Internet
I just purchased a Acer Netbook 10.1 wireless. Do I need to enter a security code in order to get on the internet.
No, you do not need to enter a security code to get on the internet. You have to use an ethernet cable to connect the wireless router to your ADSL modem. Your wireless router should first be configured with an IP address that will allow it to communicate with the modem. However, if it works you should configure a security code on your wireless router to prevent others from connecting via your wireless without permission.
Feb 08, 2011 | Computers & Internet
I am changing to a new PC, from one that is already connected to a ASDL+ modem and a Linksys router. Do I need to install new drivers(for ASDL+ modem or Linksys router) in the new PC? Or can I just plug...
For you to use the modem direct - you may need drivers - BUT connecting to a router does not require any drivers - and you should just be able to plug in and go If wireless - then you may need to provide the wireless security key if the wireless is secure - and if the wireless is on the same SSID name as before that may cayse a problem - but you can renove the xp wireless profiles to overcome that Wireless Profiles
  • http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  • http://www.tp-link.com/support/showfaq.asp?id=186
- delete the preferred networks start>control panel>network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button you will then have to enter the wireless security key for any networks you connect to
If on a LAN connection - you may need to turn off the modem/router and PC - then turn on the modem - allow to settle and all the light to show normal status - turn on router and do the same then turn on the PC
Apr 13, 2010 | Linksys Wireless-G Broadband Router
My modem is sagem i cannot put security code for wireless connectivity
The wireless security is being set on the router's admin page and not on the modem... by default the IP address of the router is 192.168.1.1, you may access it via your Internet browser....
Mar 12, 2010 | D-Link AirPlus DI-524 Wireless Router
Install wireless modem
I assume you mean wireless router. Connect the dsl line to the modem and the modem to the wireless router and you are good to go. Securing the wireless router is another topic.
Jan 20, 2010 | Dell Latitude D510 Notebook
Where is the security code to connect to the wireless gateway 2wire?
Usually you can find the security key for the wireless on a 2wire modem/router underneath it there's should be a 10 digit key in there as the wireless security key, if you cannot find it there you need to access the router setup page and it will be better if you can contact 2wire support to walk you through in getting that key from the router page..
Aug 10, 2009 | Gateway 56K Modem (Half Height) (1529412)
No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Connect Wii via wireless router
The modems wireless feature is always on. For some reason entering the security code wasn't working so I turned off the security feature and it worked fine. After the wii downloaded updates I turned on the security to the most secure settings and everything continued to work. I guess maybe the wii update fixed the issue or I just needed to change to the most secure setting.
Jan 02, 2009 | 2wire (1000-000057-000) Modem
Security code
if you are using a siemens 4100 modem alone.. siemens 4100 modem has no wireless capabilty unless there is a wireless router plugged in..
if you already have a wireless router.. the SECURITY CODE shud be provided by your wireless provider
REMEMBER: SIEMENS SPEEDSTREAM is not wireless capable
Jun 26, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
