Can't scan When trying to scan via software I ge "Unhandled exception has occurred: MSG_OpEnds faild with result 1 and condition code5 Error code 1-2010. When trying to scan using the printer button, it just stalls with no message. However, if I disconnect the printer from the computer it scan's ok to a card inserted in the printer
  • coyote04 Mar 12, 2009
    I am trying to scan an item. It tries to download the apps but then a message pops up saying that it can not retrieve applications list.. What could be the problem
    Genius:
  • 3,587 Answers
Ok..let's examine this..
operating system and model number of printer, please..
Posted on Feb 27, 2008
Getting unhandled exception has occurred in your application. How do I correct this
means that it went out of bounce. restart again and try not to go out by calculating too much... it's like a calculator e error, when
the memory runs out. no correction need on this except the programmer or the hardware, like run out of memory!
Jan 21, 2015 | Avanquest My Invoices & Estimates Deluxe...
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
We get an error message when trying to access reports - that an unhandled exception has occurred. The detail refers to jit debugging
you have a virus you need a a good few scans start with a free antispyware scan superantispyware free should do it i thinki and a virus scan hmmm avast home free but normaly thats a report of windows being infected and deleted
Jun 27, 2010 | Avanquest My Invoices And Estimates Deluxe...
.netframework unhandled exception error
Hope this might give you a rough idea..... i think there is a way in which we can make the program not to show any error when any error occurs in the program that we write...,
the code for that would be something similar to
.NET CODE
"On error Resume Next"...
Oct 05, 2009 | Computers & Internet
Unhandling error
How do I correct an "Unhandled Exception" error received while editing a scan from my all-in-one printer? Question : How do I correct an "Unhandled Exception" error received while editing a scan from my all-in-one printer? Answer : To correct an Unhandled Exception error received while editing a scan:
  1. Open the Control Panel on your computer and double-click Display.
  2. From the Display Properties window, click the Settings tab, and then the Advanced button.
  3. From the "DPI setting" drop-down list, select Normal size (96 DPI).
  4. Click OK and close all open windows.
  5. Restart your computer for the changes to take effect.
May 04, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
An unhandled win32 exception occured in svchost
Windows error from some component of your browser most likely. Try reinstalling the web browser (and rebooting if it's Internet Explorer).
Apr 07, 2009 | Computers & Internet
Unhandled Exception message with new 5300 AiO
go to c:\windows\system32\kodak and check for kds_aio5000 and inside that you should have 1 folder and 1 file. the folder name is lib and the file name is ekaiowia.dll. inside lib folder there are cct.ekpgct and hippo.dll. If not then uninstall the home center and then go to www.kodak.com/go/clear and run it then install the home center from www.kodak.com/go/downloads and choose the appropiate product.
Jun 06, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can't scan with Kodak Easyshare 5300 printer
My Scanner (Barely used, not even through the first set of ink cartridges yet) was working beatifully. Then all of the sudden the same thing happened to mine...blinking lights...Power light flashing Yellow...I contacted Kodak and they had me do the same old thing...Unplug, uninstall, reinstall, restart. Nothing works...They also try and have you redownload firmware (But Hello....You cant if the printer isnt ON!) So I went back to them again to say none of it worked. They said its the print head and they are sending me another one. Ive read a lot of terrible reviews of this printer just because of the crappy print head...You would think they could fix that by now, or have 5 extras in the package when you buy it.
Feb 27, 2008 | Office Equipment & Supplies
Unhandled exception error after installation
uninstall software and reinstall the software with usb cable not hooked up to the printer.
Dec 05, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
141 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
