Memory inserted Wrong side
Hi there
A friend of mine with a Medion Multimedia Computer with P4 Sockel 478B has actually made it to Insert two Memory Modules on his Computer but one of them the Wrong side. He said that those things on the side closed well but however he was not sure he tried to start the Computer and it went on but no Boot Process, No Beeps and no Image came up. He shut it down and after looking closer he finds that one of the Ram Sticks was inserted the Wrong side.
After he tried everything inclunding the old Working Memory Modules but allways the same Result: No Image, no Boot Process, No Beeps and the Power Light on the Front of the computer doesn't light up with the computer anymore.
Is it possible that this could have done any damage to the Mainboard?
What could be damaged? Is it possible to Repair?
I tried to change the Graficcard nad the CPU for Him but with the same result.
Please any Help would be very Welcome.
Thank You
Regards
Peter
  • Picas Feb 27, 2008
    Thank you.
    If one Socket is damaged, shouldn't it be able to work it a memory stick on a different socket?
    Thank you
    Regards
    Novelist:
  • 139 Answers
Unfortunately the memory socket has probably been damaged. An experienced electronics technician might be able to replace it, but the board could easily be damaged by the replacement work. It would probably be best to replace the motherboard in this case.
Posted on Feb 26, 2008
  • networkmagic Feb 28, 2008
    Bent contacts in the damaged socket are probably shorted together which can disable the board....or some of the power supply circuitry could have been damaged as well.
How do I download my movies onto a memory card on medion lifetab
Hi
If the pc has a card reader built in insert your card into the relivant slot and then you can just use computer / My computer to drag and drop the files from the PC to the card.
If you don't have a card reader you will need to buy a card reader that plugs into your USB socket, then you can use drag and Drop to copy the files
Cliff
MCP
Aug 23, 2014 | Computers & Internet
Sir,i have medion md 7425 digital camera yesterday i saved picturs into my laptop and formated the memory card.after this i disconnected camera from laptop.and i switched on my camera it does not...
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Aug 11, 2010 | Medion 9653 Digital Camera
    I have optiplex gx60 desktop system running
    No problem, it's the same generation so it will work just fine.
    May 26, 2010 | Dell OPTIPLEX GX60 Motherboard
    My kodak camera keeps saying that the internal
    The internal memory is small. Your camera will continue to write to it until you erase the pics from it. Here's how...Remove the memory card. Download any pics you want to save from the internal memory. Go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Insert your card. It should work properly now. Promise yourself to never use the internal memory again.
    Apr 29, 2010 | Kodak Easyshare C182 12MP Digital Camera
    I can't find my install cd and I can't get pics off of my old phone onto my computer, help! These are valuable since I took pictures of President Barack Obama when he was campaigning in Texas. I really...
    hi,
    does your phone have a memory card?
    if yes, do these..
    >>if the pictures is stored in your phone memory, then copy the pictures from your phone memory to your memory card. once copied, switch off your phone, remove your memory card, get your memory card adapter, insert memory card and insert it to your laptop sd reader slot and copy the files from your memory card to your laptop. if you use desktop and has no sd memory card reader slot, borrow memory card reader from a friend, connect it your computer, insert the your memory card from there and once read, copy the files to your computer. this also is applicable if you want to copy files from your computer to your phone.
    >>if it doesn't have, then, borrow a bluetooth dongle from a friend, pair it with your phone, and send the file from your phone, one after the other...
    good luck..
    Feb 21, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
    I have a medion steering wheel with xp drivers. Can i use this with in vista
    Hello my friend,normally no but in some situations xp drivers work on vista but you can do another thing.Insert your wheel on your computer and maybe vista will find the drivers automatically or ask you to search on the internet.If nothing found you can try your xp drivers
    Feb 06, 2010 | Medion MD 96340 Laptop
    My friend has just rung me he has got medion akoya p7700d beep problem when he turns the tower on.what should he do now please?
    if it is a continuous beep its from a Ram memory issue ...just get out the ram and insert it again ...also remove the battery from the bios for a few seconds...it will boot again if the Ram memory is still ok ...if not ...just use them one by one if there are multiple ..or replace
    Dec 20, 2009 | Office Equipment & Supplies
    I need to replace the chip 478b, because to pins are broken off. I want the same or a compatable one for my motherboard P4 X 400DBP. Where to get/buy the chip would be a good start. Intel P4 processer...
    Hey man, found you one cheap at the following link. Don't forget your thermal paste, very important.
    http://www.weirdstuff.com/cgi-bin/item/13363
    Jun 20, 2009 | Computers & Internet
    Hi
    When you insert a memory wrong side and try to boot the computer, there are chances that it may damage the motherboard. Also it may or may not give any beep sounds.
    You may try booting up the computer without any RAM sticks in the slots. If you do not get any beep sounds, then it is definitely an issue with the motherboard.
    Once you do that, take the computer to a local technician or you manufacturer service centre and get it checked.
    Feb 26, 2008 | Medion MD-1704 PC Desktop
    Inserting sd photo memory card
    If you have to force it, you are inserting it the wrong way. The cards will only fit one way.
    Jan 07, 2008 | Office Equipment & Supplies
    Computers & Internet Logo
    56 people viewed this question
    Alun Cox
    David Payne
    David Payne
