FixYa.com
Tags:
NEC VT676 Multimedia Projector
Bright yellow (by 3 users)
posted by cgoric on Feb 26, 2008
Whole screen took on bright yellow shade as if projector bulb was yellow, how do I get back to normal
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 10, 2008
The whole screen isn't yellow, just a large blob in the centre that looks like a tin of paint has been thrown at the screen
Comment by Guest, posted on Jun 03, 2008
Solution #1
posted on Feb 26, 2008
Not Rated (0)
Matt UK
Rank:Guru Guru
Rating: 88%, 87 votes
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
Matt
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
ge vivid i does not start...
begun re-starting several times... Answer This...
Dots on projector screen.
Philips UGO series Mulitmedia... Answer This...
(old) InFocus LP335 Projector -...
I recently had my boss walk... Answer This...
Projector won't stay on
I have a Sharp XG H400U LCD... Answer This...
NEC LT170 projector won't turn...
Why won't my projector turn on... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
