Question about LG RH177 DVD Recorder/HDD Recorder
LG RH7796W DVD/HDD Recorder
On playback of timeshift, sound is out of sync with picture
  • Anonymous Mar 31, 2014
    Playback freezes at times and at others appears to skip parts of scenes
The problem has fixed itself, thank you
Posted on Feb 27, 2008
What is the settings for playback?
There are no specific settings for playback on this machine?
If the lazer does not read discs and the display shows NO DISC or UNKNOWN DISC then the lazer pick-up needs replacing.
I believe that the lazer pick-up for this LG recorder has been discontinued?
Jun 22, 2016 | LG RH1999H DVD Recorder/HDD Recorder
My LG DVB-T HDD/DVD Recorder will not play or record sound via TV Channels!
If the TV source is separate from the recorder, there has to be a physical connection between the two. From your description it seems there is a video connection, but what about audio?
Dec 03, 2013 | Televison & Video
How to fit new dvd drive in LG RH7796W DVD 250gig recorder? I've had a serviceman tell me that the 250g HDD needs replaced. I do not want to pay $300 I would sooner have a go myself. Thanks
Open up your LG Recorder. You should see the HDD on the left, the DVD drive in the middle and a circuit board on the right..
Now, look at the back of the dvd drive.. you should see a power connector and a standard IDE interface..
Remove both of those connections carefully. Remove the screws in the black bevels on the sides of the drive and slowly pry out the drive by lifting the IDE interface side above the main board and pulling it out while slipping out the black clips on top of the tray side..
Now that it is done, take your new dvd drive.. you may want to remove the faceplate or at least the plate from the tray ..(slide it upwards.. it should slip out ) .. Place it where the old dvd drive used to be.. do the connections and your good to go..
Before closing, Check to see if the drive is functioning. Close up.
I have swapped drives on my LG many times and even upgraded the HDD.. I have used mainly LG and sony drives..
Mine was originally shipped with 80GB some 3 years ago.. I had put in a 160 GB and now will be putting in a 250 GB as the other is already full and i like to keep those old recordings..
May 29, 2010 | LG RH1999H DVD Recorder/HDD Recorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
No sound output on highlander dvd recorder/hdd(80g). We did have for nearly a year, but a month ago sound output stopped. ie. we can burn from hdd to dvd & play in another machine & it has sound -...
Ive just had the same thing happen to my highlander dvd/hdd 160g.
Mine lasted just over a year and I have lost the sound as well. It worked perfectly and No problems until sound suddenly disappeared
Nov 19, 2009 | Televison & Video
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
I own a lg rh399h dvd recorder. I have finally figured out how to record from dvd to hdd, but it records in real time (slowly). Does anyone know how to :fast copy'' from dvd to hdd???
LG HDD/DVD RECORDER RH399H
Insert an empty DVD + R. The system asks whether to format - Format.
Select a recording on the HDD to copy to DVD.
Enter
Select dubbing
with arrows select type of recording to make (XP, SP, EP etc)
The system show the duration you can copy to you DVD. If small enough the FAST option also appears.
If big copies while playing the orriginal (I.e. playback speed)
Aug 28, 2009 | Audio Players & Recorders
Time shift to hdd
The only way I was able to do it is to capture "while playing back" to another recorder "VCR" DVD"
Dec 10, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Transferring from timeshift buffer to hdd
When in timeshift, press record on the remote (every time you push "record" 30 minutes are added) and make sure the program you are recording is not macro protected. If your program has already finished rewind to the beginning of the program and push record the correct number of times to cover your program and then press stop on the remote. It should then be at the bottom of your hard drive list.
No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Apr 25, 2008 | LG RH-4820 DVD Recorder
LG RH177 DVD Recorder/HDD Recorder Logo
411 people viewed this question
Computer Repairing
Computer Repairing
