Question about Maytag MSD2454G Side by Side Refrigerator
Refrigerator is freezing on the produce side
I have a Maytag Refrigerator modle MZD2667HEW. It is freezing on the freezer side and also on the product side.
    President:
  • Maytag Master
  • 2,651 Answers
If you get frozen fresh food the air damper is not closing allowing too much freezer air to enter ff section, looks like an electronic controlled wide by side you have, ther should be a tch sheet with a troubleshooting guide behind the kickplate or pasted in an envelope under the front of refrig behind kickplate.
Posted on Feb 27, 2008
Maytag refrigerator
ea5703cb-9dae-46dc-802e-aff05e1adbe2.jpgYou may have defrost component failure. What is the model number of your Maytag? Sea Breeze
Apr 23, 2013 | Kenmore 50522 / 50524 Side by Side...
Which way do you turn the dial for changing temperature control to make it quit freezing all our food
If there is a off position, That will be the direction to turn it higher. Make sure the seal on the door is working properly. It can cause ur problem
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 01, 2018 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
My Maytag refrigerator is freezing my fresh produce...it is a bottom freezer with in-door ice/water dispenser...how do I solve this?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
Wall between fridge and freezer is very hot
I understand you are a little irritable about your Maytag. If you would like the service manual or one on one help free free to let me know. Your refrigerator is a complex refrigerator. But quality is Maytag. They are the only company that I know that will go out of the way to insure their customer is satisfied. If you would like the service manual or personal assistance, please let me know, Sea Breeze
Jul 11, 2009 | Maytag MZD2766GES Side by Side...
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
152 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
