Cars & Trucks Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 97 dodge ram 5.9L does not shift into od it
My 97 dodge ram 5.9L does not shift into od it might for awile then go back off help me i cant hear it shift into highway gear and my rpm"s are running higher than they should be
Anonymous
Level 2:
New Friend:
  • Expert 148 Answers
  • Posted on Feb 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
148
Questions
0
Helped
75706
Points
414
If this is a 5.9 diesel Clean all the battery terminals, especially clean all the wires on the drivers side battery. Give me feedback if this helps
Why wont my transmission o/d work
no engine told. size, this tells what transmission sites behind it.
1999 Dodge RAM 1500????? not VAN. 1500
2wd or 4wd'/
5 engines. then.
check all fuses, some have stand alone TCM brain (tranny)
scan the PCM for P07xx error (tranny)
check ATF levels hot, park ,idle, only do not overfill it ever.
ATF+3 (not sure but do check)
they used 3 transmission then
4-speed 42RH-RE automatic
4-speed 46RH-RE automatic
4-speed 47RH-RE automatic
42RE , is electronic shifted,
OD gear is dead or just the TCC lockup deaD
best is count the gears more carefully to see truth.
yes 4th gear is OD Geared. 3rd gear is 1:1 lockup.
.74-to-1 for first, 1.54-to-1 for second, direct 1.00-to-1 for third and 0.69-to-1 for fourth.(OD)
scab the PCM
to see if errors from the transmission show up.
I bet they do.
the 3>4 shift solenoid must work, .and no pressure errors.
the schematics show an OD switch if not closed OD does not happen, forget about that switch>
if car is 4wd and is in 4wd, many cars/ and truck all shut off
OD in 4wd, by logic inside the PCM (pure) my not be true on the biggest engine not told.
I have a 97 Dodge Ram 1500 5.9 V8 gasoline engine. Recently had the front and rear seals replaced. I noticed shortly thereafter that the transmission would want to wind out then slam into 3rd and OD....
The linkage needs to be adjusted. It should be the one from throttle to transmission. They have to be set properly or vehicle will not shift correctly.
2answers
My 2002 dodge ram diesel wont start
what led up to the no start
2answers
Dodge ram 3500 turn signal - headlight problem
WAY TO GO !!! another "great idea" from vehicle manufactures
1997 dodge ram 3500, it shudders in OD
Hey, I also have a 98 ram with the cummins and what you are talking about is when you are pullin hard in overdrive the trans is working to hard causing the shudder, when this happens back off the throttle and get back on the throttle to allow the trans to downshift. If you dont it will break the overdrive gear. There is nothing wrong with the trans it is just that it is shifting to early and bogging down causing the shudder.
Mass air sensor on a 2000 Dodge Ram 2500
inline of air duct (plenum) after air filter
95 ram 2500 4x4 wont shift into od
ckeck linkage they might have undone iy and not put back in right place
97 dodge ram transmission prob
sound like a tork converter problem or the shift solinoids are faulty or internal damage have it scanned hope this helps
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
