Question about GE WSXH208A Front Load Washer
GE Front Loader Washer
My front load washer began to rinse out the towels I was washing, then suddenly shut of with a lot of time left to wash. Now the washer won't turn back on. What do I do?
  • Tiffany L Feb 26, 2008
    Thanks, this did the trick!!
  • geadora Jun 29, 2008
    I have similar problem, I hold the signal button for ten seconds but nothing happened. machine doesn't turn on, I have checked the wall plug which has juice. Someone, please tell me what to do; is there a fuse somewhere for the GE Adora?which is hidden like lint trap that I can't find it (I cleand that too). I think it was my biggest mistake to listen to the suggestion of homedepot's salesperson to spend my money and time on this piece junk from GE.
  • 1,554 Answers
Towels are heavy so it likely became unbalanced and triggered a shutdown.
press the signal button for 10 sec
Posted on Feb 26, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service
Jan 28, 2016 | GE Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My washing dries coarse since I purchasing my Asko front loader. Towels and socks in particular. What can I do to stop this from happening?
Use a washing softner in the final rinse water such as Downey Apparently you have hard water that lealeaves precipitated minerals in your clothes.
Feb 05, 2011 | Asko W6661 Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Water softener goes in at wash cycle rather than rinse cycle
if it has to go in the rinse,,this means you have to put it in the fabric softner compartment of the dispencer,,,also do not fill pass mark fill line in dispencer or it will sphion down by itself before time..onthejob
Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
I just got a brand new GE Front Loader Washer & Dryer.
No, but it depends on in part on what cycle you selected. Did you happen to choose one with an extra rinse cycle?
Jan 22, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Odors on the clothes after washing in Maytag front loader
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
try unplug and leave for 30 min
please give me machine number so i can help you further
Feb 26, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
140 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
