Typewriter tab settings
How do I set tab settings?
  • 106 Answers
What is the type of your typewriter
Posted on Feb 26, 2008
DaveAyre
  • 19 Answers
SOURCE: won't remember tab or margin settings
Should be a back-up battery on the pcb.This needs to be replaced... Dave,, Ulster,, Northern Ireland..
Posted on Mar 16, 2007
  • 329 Answers
SOURCE: Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Posted on Aug 01, 2008
SOURCE: My set margins and tabs clear from memory when I
I was able to reach someone at Brother. He said that the typewriter does not store the margins and tabs. Seems unusual to me, but I guess I will have to take his word for it unless someone out there knows something different.
Posted on Jul 23, 2009
  • 3594 Answers
SOURCE: how do I clear the tab settings on a swintec 4040
Indivually tab to the one you wish to clear press T CLR key, to clear all tab all the way to the R. hold tab clear and touch return.
DickyO
Posted on Sep 21, 2009
Testimonial: "it wasn't the exact answer, but it lead me in the right direction and I found it. Thank you! Now if I can figure out how to set a decimal tab I'll b"
  • 1218 Answers
SOURCE: How do you set the tabs on the Olympia Startype
GO TO WWW.NADIST.COM AND DOWNLOAD THE MANUAL FOR THE NAKAJIMA AE-740....ALL INSTRUCTIONS ARE IN THERE.( Its the same machine and the manual is FREE.)
Posted on Jul 12, 2010
I have a vintage Sears The Graduate typewriter, but can't figure out the tabs. I can set my margins, but I don't know how to set the tabs. Thank you
Normally same button sets or releases tab mechanical. Next button releases tab to next setting play around or look for the service op,man on internet
Oct 23, 2014 | Office Equipment & Supplies
How can I set a right hand tab
I assume you are talking about Flush Right Tabulation.
To set a flush right tab:
(1) Position the carrier (or cursor) at the point where you want a flush right tab to be set.
(2) Hold down the Tab set/clear key and press the 2 key.
To clear a flush right tab:
(1) Press the Tab/back tab key to move the carrier (or cursor) to the flush right tab position.
(2) Hold down the Code key and press the Tab set/clear key.
To use a flush right tab:
(2) Type the text. Characters will appear on the display as they are typed. Corrections can be made on the display before the text is printed.
(3) Press the Print key. The text is printed aligned with the flush right tab position.
To find out more about your Swintec 7040 typewriter, you can buy a PDF manual for only $10 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
May 15, 2014 | Swintec 7040 Typewriter
Return to tab
Don't confuse tabs and margins, after a return it always goes to left margin. Use the tab key to go from the left to the next place where you set a tab
Jan 30, 2014 | Nakajima AE-740 Typewriter
How to set tab i want to set on 75 and it remains on 60
Tab to 60 press tab clear key, space to 75 press tab set key. To clear all tabs space to rt. end hold tab clear key and press return.
DickyO
Mar 01, 2010 | Nakajima AE-740 Typewriter
How do I Delete a tab setting?
The usual method is to tab to the point to remove and then either toggle the tab with the set or remove tab key.
Nov 09, 2009 | IBM Wheelwriter 30 Typewriter
How do I set Decimal Tabs?
From the User's Manual:
Margins and For each setting, move point. key(s) indicated:
• LMar to set left margino
• RMar to set the right margino
• MarRei to the!" left of the margino
• TSet to set a tab. Vou set at the left and right margins. Vou • TClr to clear a tab.
• TClr + CRln elear ali The earrier does not margino when the carrier is tive margino Vou type or space through ríght margino saved when the oft.
Tabs
the carrier to the desired point, and press the
the margin.
margin.
MarRel release the left margin, ther Backspace or +- to move
margi n.
You can up to 26 tabs. Permanent tabs exist
You cannot clear these tabs.
CRtn to clear all tabs.
carrier lock at the right margin. The typewriter beeps
about five spaces before the right margin. You can
the right margin. Margin and tab settings are
typewriter is turned.
You can download the User's Manual from LEXMARK:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Look for the title 'IBM Typewriters' at the end of the page, open the list box and select your typewritter model.
Aug 07, 2009 | Lexmark Wheelwriter 1000 Typewriter
Changing tabs and move the right margin over some
On the L. side of the T/W ketboard are the keysmar left, mar right,tab set, tab clear and mar rel. Space to the location thayou want th R. mar and press right mar key, if it stops at the R. mar. press and release the mar rel key. To clear tabs tab to the one you want cleared and press tab clear. To set a tab space to the position and press tab set.
DickyO
May 26, 2009 | Nakajima AE-740 Typewriter
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
Tabs
Move the printhead to the position you want a tab set. Then hold down the CODE key and hit the key under where T SET is printed above the keys on the keyboard. Do this for every tab you want to set. If you want to clear a tab set, tab to the one you want to remove and hold down the CODE key and hit the key under T CLR.
Sep 22, 2008 | Brother GX-6750 Typewriter
Won't remember tab or margin settings
Mar 16, 2007 | Brother SX-4000 Typewriter
256 people viewed this question
jasbo
jasbo
