Question about GE WSXH208A Front Load Washer
GE Front Load Washer
My front load washer began to rinse out the towels I was washing, then suddenly shut of with a lot of time left to wash. Now the washer won't turn back on. What do I do?
  • 487 Answers
Try unplug and leave for 30 min
please give me machine number so i can help you further
Posted on Apr 15, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
LOUD BANGING
The light blinking is normal if the it is .5 seconds and and .5 sec off. Means it is in standby. The washer must be level front to back and left to right, do not wash heavy single item like rugs. If you was towels or sheets you may have to untangle then in order for them to be evenly distributed around the tub. Also, make sure you have the washer settings set for fabric softener added. It will then fill for the final rinse , instead of a spray rinse. Good luck.
Feb 13, 2014 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Moldy smelling clothes
First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
Jul 01, 2009 | LG WM-0532HW Front Load Washer
I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Feb 24, 2009 | General Electric WBVH6240HWW Front Load...
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
GE Front Loader Washer
Towels are heavy so it likely became unbalanced and triggered a shutdown.
press the signal button for 10 sec
Feb 26, 2008 | GE WSXH208A Front Load Washer
Washer not rinsing or spinning but doea go around
Loakes, the first thing you want to check is the drain pump. Remove the lower panel and it will be on the right. If the pump is not working the washer of course will not drain and will not go into high spin speed. You will need to verify that first it is getting voltage and second there is nothing jammed in it. Get yourself a pan and a bunch of towels and remove the hoses to it. You will have a lot of water coming out at you. Check the pump impeller and see if something is caught in there. If you still have problems after doing this, some tests will have to be made to determine the problem...Catriver..post back.
Aug 28, 2006 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
95 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
