E-Machines eMachines Desktop PC Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is continually running and the screen is not showing up. Brand new hard drive
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 163 Answers
  • Posted on Feb 17, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
163
Questions
0
Helped
31049
Points
493
Few questions here if you have an answer for will resolve this.
Is the system screen showing any message at the begining ?
If yes its not a problem with the monitor.
Check the Bios, if its accepting the harddisk. Initially while the system Just begins to run the bios.
If the Harddisk is detected in the Bios well and good. Else you need to check if the harddisk is connected properly to the mother board, if yes you may check if the HDD is compatible.
These steps should resolve the issue. Good Luck.
Continuous blinking
MY LG LSD TV SCREEN IMAGE IS CONTINUALLY BLINKING AND A GREEN VERTICAL LINE ABOUT 3 IN SHOWS CONSTANTLY IN THE SCREEN
Help how to format lenovo ideapad s300 in windows 7
If you want to format your entire hard drive (and reinstall windows) You'll need to insert the appropriate windows disk. If you want to reinstall 7, insert your windows 7 disk and boot off of the disk (When booting, it should start by showing a screen that says "Press any key to boot from CD..." and you can just press a key on your keyboard. From there, follow the on screen instuctions. When you get to the drive partitioning step, select your hard drive and partition you want to format. You can delete the partition you have and make a new one if you want to totally clean the computer (WARNING: This will literally delete everything on your computer. Everything). From there you continue and finish the setup (it may run for a while). And you have a fesh new hard drive and operating system install.
1helpful
2answers
How to format windows XP from CD
Here is The Step By Step Guide to Format or install win xp from a bootable CD
(Warning: Do it at your own risk, Back up all you data before formating the drive.)
Step1-Insert the windows XP cd in your cdrom and than go to the BIOS by hitting "DEL" or "F12? when your system in powering on. Go to Boot order and make sure cdrom is on the first place.
Save settings and restart your computer.
Once you have successfully booted from the CD, you will see the Windows XP "Welcome to Setup" screen. Press ENTER to begin the setup process.
Step 2- License Agreement
When it shows about License Agreement just press F8(function key) to accept the agreement.
Step 3: Previous Versions of Windows XP In this step setup will search for existing Windows installations. after search complete will see two option "R for repair or Esc to install fresh copy"
Note:screen will appear only if a Windows installation is already exists on your pc. If you're installing on a brand-new hard drive,you have to skip this option and see step 5.
krbshg_1.gif Step 4:To Continue installing fresh copy
Press ESC. You will be given a list of partitions available on your hard drive.
Step 5: Partitions If there are multiple partitions on your hard drive, or you have multiple hard drives in the computer, use the UP or DOWN arrow keys to choose your install partition. Please note that your system partition needs to be a primary partition (usually the first partition that shows up in the list), not a logical partition.
The partition should be at least 10 GB in size. Make sure that all the data you need from this partition is copied elsewhere, because it will be deleted.
Once you have selected the right partition selected, press ENTER. You will see the next "you already have a system installed" screen only if you already have Windows installed on this partition. If you are installing on a brand-new hard drive, skip to Step 7.
Step 6: Continue Installing On The Selected Drive Press C to continue. You will be given a list of install options
krbshg_5.gif Step 7: Format The Selected Partition Select the option to "Format the partition using the NTFS file system (quick) and press ENTER.You will receive a warning about formatting the drive unless the drive is brand-new.
krbshg_6.gif Step 8: Continue With The Format Press F to continue formatting selected partition. If you still haven't backed up, this is the last change to backup your important data, after this step you will not to able to go back and restore your data.
krbshg_7.gif Step 9: Copying Files After the format setup will automatically copy files and restart your computer. Go to BIOS and remove cdrom from first boot device. Start your computer.
krbshg_8.gif Step 10: Automatic Installation After RestartSetup will continue to install after the restart. it will ask you for the product key and user name etc. Fill the forms yourself.
Hi there, have a strange problem with a brand new DVD SAMSUNG SH-S223C. Installed a few days ago and running latest SB05 firmware (Even I reinstalled twice this firmware). Now on boot with my WIN XP PRO...
Start up BIOS and perhaps change default boot drive to your hard drive because i think your default boot up device is the dvd drive.... try to put that last on the list... F2 should get you to BIOS if not try F8 Just keep tapping right at beginning of startup before the logo screen shows. Once in BIOS go to boot menu and change default device :) Hope that works for you
2answers
My brand new seagate hard drive is showing on 120 gb space on partition time?
it means your hard disk have 120 gb capacity, you can make partition according to your requirement.
Keeps continually running and the screen will not come up. brand new hard drive
Hmmm did you biuld this system...what's the OS??
Is the mother board happy?
Hello, I have a LaCie 250GB Hard Drive and it´s not being recognized by my PC. I have Windows XP SP3. What should I do?
All brand-new hard drives are sold unformatted and thus don't show up in Windows until they've gone through the formatting process. To get up and running, connect the drive, boot your PC, and at the Windows desktop right-click the My Computer icon and select Manage. Click Disk Management in the left-hand tree, and every drive connected to your system will show up. Simply right-click your new drive and select New Partition. Then follow the steps to get your drive up and running.
1helpful
2answers
How to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
