Question about TechSmith CAMTASIA STU V1.0 5-9U for PC
Camtasia Preview Windows is blank
I have downloaded the Camtasia Version 3.
The clip appears in the Clip Bin as well as in the TimeLine Sections but I can not make it appeared within the Preview Windows.
Who will be the first to give me a hint!
Thanks
  • 3 more comments
  • Anonymous Mar 22, 2008
    SAME DEAL!!!
  • willr Mar 27, 2008
    i've got new trial version of Camtasia 5. the preview window is blank, no pictures or videos show.
  • Anonymous Apr 03, 2008
    I just downloaded version 5 of Camtasia Studio and I'm having the same problem. No preview which makes it impossible to edit.
  • dahawe Nov 25, 2008
    Same issue; I have the full version 5.0.2 and although the quickstart guide shows clearly that the preview of powerpoint or recordings should show immediately after ending the recording, my version did not do this.
    Also I doubled the RAM and still no help.
  • Anonymous Feb 24, 2009
    I have the same problem on vista and that "troubleshoot" i cant find :(
Doesn't work for me
Posted on May 03, 2008
O.k.
Posted on Feb 27, 2008
HP Smart web printing clips doesn't appear in clip book
I've just tried this for the first time and get the same problem. I'm using IE7 (32 bit) on Vista 64bit. Print works, but not clip.
Jan 17, 2009 | Office Equipment & Supplies
Clip Art in Microsoft Word 2007
Enable "picture place holders" from Office button -> WordOptions -> advanced
Oct 23, 2008 | Microsoft Office Professional 2007 Full...
Extremely slow to update changes on timeline...
This is a known issue when too many edits are made. Supposedly Camtasia Studio 6 (recently released) will decrease your editing time by 30%. I have not been able to verify this yet. The best way to resolve the issue is produce what you have as an AVI and start editing that, and so on, and so on.
Oct 02, 2008 | TechSmith Camtasia Studio for PC
Memory Problems
The clip can be recovered if you open the temporary directory where Camtasia stores the raw captures in AVI format. The path to the temporary directory can be found by opening the Camtasia Recorder > Tools > Options > Program > Temporary file folder (I'm using v.5 so it may be a little different in other versions).
I've found that there's a certain workflow that seems to work best and you can avoid accidentally erasing your temporary files and having to start your capture session over from the beginning...
  1. Stop Camtasia Recorder - Pressing the Stop button on the Recorder likely won't work, so open the Task Manager (CTRL+ALT+DELETE) and select "CamRecorder.exe" from the Processes tab and click "End Process". Don't open Camtasia Studio right away after doing this step - You'll likely be prompted to recover the recording and in my experience Camtasia hasn't done a very good job at being able to do this successfully and you may end up losing your temp files.
  2. Recover your raw capture files - Navigate to the path where Camtasia stores its Temp files (look above for instructions). Typically, there will be a folder titled "CamCapture{random string of numbers/letters}" - look for a folder with a date modified attribute of the date/time you were working on your project. In that folder, there will likely be several audio and video files as well as an XML data file. The video files will all be 1GB apiece as Camtasia splits the capture into chunks and then pieces them back together to create one continuous file. Cut and paste the files from this folder into a new location outside of the Temp directory. The most important one is the FileWriter{random string}.avi as this is the pieced together file - It will have the largest file size.
  3. Add your media files to the clip bin/timeline - Start a new Camtasia project and import the FileWriter{xxx}.avi clip into the Clip Bin and drag it onto the timeline. Now all of your video/audio should be recovered and available for you to edit. If you have particularly long clips, you may want to check how the audio syncs with the the video towards the end of the clip. If it's messed up at all, you may want to try adding the smaller, chunked recording segments sequentially onto the timeline to see if that helps. If the FileWrite{xxx}.avi clip is good though, you can delete all of the other smaller audio and video clips associated with the capture from your pc to save space - just keep the FileWriter{xxx}.avi clip - the XML can be deleted too.
Good luck - We've had the same trouble here and we use Camtasia almost everyday. In my experience, this seems to happen more frequently when we capture larger dimensions - especially if the capture contains full motion video (as opposed to just screen captures of a product demo or something) and we always seem to have trouble when capturing things that play back FLV or SWF clips at a higher bitrate. This issue is also described in TechSmith's Camtasia knowledge base.
Apr 22, 2008 | TechSmith CAMTASIA STU V1.0 5-9U for PC
Still Images from a Movie Clip????
If you are using windows xp then it is easy, get in movie maker in xp. Play the clip in the preview monitor.
    • On the Play menu, click Play Storyboard or Play Timeline, depending on the view you are working in, and then pause playback at the frame of video you want to capture as a picture.
  1. On the Tools menu, click Take Picture from Preview. -or-
    On the monitor, click the Take Picture button.
  2. In the File name box, enter a name for the picture file, and then click Save.
Mar 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
How to rotate movie in movie maker
Vista
Start - Programs - Windows Movie Maker
Click Import Media - select the video clip you want to rotate from your files and point and click on it to highlight it - then click the import button lower right corner of screen.
When the file name appears - drag the clip to the video line at the bottom of the screen - point at file name and hold down right mouse button while you move the mouse to point at the video timeline then let go of the right button to drop the video into the timeline.
Point and RIGHT click on the clip you just added to the timeline
Click Effects
Scroll down to Rotate 90 and click to highlight it (you could also flip the video with 180 or 270)
Click the ADD button
Then click OK
The video will rotate.
Be sure to publish and save the new video with a name you can find...
File - Publish Movie - to computer will save it as a file on your PC - to DVD will start another program to create a DVD...
Have Fun
Cheryl
Dec 22, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Transitions
You should export your two video clips and make a transition in Windows Movie Maker. This is much faster and you have a wider selection of transitions.
Aug 09, 2006 | TechSmith Camtasia Studio for PC
How to rotate a video clip I took vertically??
Vista
Click Effects
Then click OK
Have Fun
Cheryl
Jun 03, 2006 | Canon PowerShot S410 / IXUS 430 Digital...
TechSmith CAMTASIA STU V1.0 5-9U for PC Logo
7,435 people viewed this question
Top TechSmith Computers & Internet Experts
David Payne
David Payne
Are you a TechSmith Computer and Internet Expert? Answer questions, earn points and help others
