Question about ViewSonic VX924 19" LCD Monitor
Help my monitor has a message of out of range...any solutions?
    Sergeant:
  • 319 Answers
You will need to get a CRT monitor so you can see what you are doing to re-install the drivers for the LCD monitor.
Posted on Feb 26, 2008
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
Out of range message seen after installed new software and reboot
The monitor will display out of range message because the PC video resolution is too high for the monitor to display, the new software may have changed or corrupt the video seting, try booting up in safe mode (hit f8 while computer booting up) and set the video resolution to 640 x 480, then reboot in regular mode, then reset the resolution to the native resolution of this monitor which is 1280x1024@60Hz.
Mar 24, 2010 | ViewSonic VA703B LCD Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
Out of rang vw193t
Pls temporarily install a older monitor then check the display sttings ,set it to the lowest resolution apply and then check whether its working on the old monitor.Then shut down and connect the new monitor and power on the monitor should work
Jan 24, 2009 | ASUS VW193T Monitor
Problem with my LG monitor L194WT
Make sure you have the latest version of DirectX and 3D glide installed on your computer. You can also try adjusting the monitor frequency from control panel to something a bit higher. That should help.
Let me know how it goes. If the solution worked, please rate a fixya, if not, please post back before you rate , so we can troubleshoot further..
May 27, 2008 | Gateway FPD2275W LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
26 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
