Question about Lexmark E330 Laser Printer
My printer jams frequently
I have to keep unjamming papers nonstop. Some pages feed fine, others (in fact, most) do not. What can I do?
My guess is that the paper feed tires in the paper drawer are glazed they can be replaced or I would try using a rubber restorer or just turn them inside out that works some times.
Posted on Mar 06, 2008
It jams immediately going from the paper tray. I've tried manually feeding the paper, and that hasn't helped either.
Posted on Mar 03, 2008
  • 25 Answers
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Posted on Mar 02, 2008
How do i fix a paper jam on my printer?
One of the more common problems with printers as it relates to paper jams, is that the paper stacked in the tray hasn't been fanned. What I mean is, it's like holding a paper-back book in your hand and skimming quickly through the pages with your thumb as your other hand holds it at the spine. Try this as a remedy if your printer jams often.
Hope this helps. :)
Oct 02, 2010 | Office Equipment & Supplies
My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
Mar 28, 2010 | Office Equipment & Supplies
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
I had a paper jam and after I unjammed it the paper will no longer feed into the printer. It keeps telling me the tray is empty when it is full
Unplug from the power then restart the printer sometimes the paper is not in just right and when you restart the printer it will send any loose paper on threw the printer
Sep 29, 2009 | HP Photosmart C6280 Printer
Printer keeps on jamming
could be improper bond weight or thickness of paper, too much paper in the tray, or the wheels on the feed rail inside is broken or needs to be cleaned
Sep 25, 2009 | HP OfficeJet J4580 All-In-One Laser...
Only 8 1/2 by 14 paper jamming at the DADF
Does it feed sometimes, and just jams frequently, or every single page?
Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
Mar 16, 2009 | Office Equipment & Supplies
Paper no longer feeds at all
Open the top where you exchange the cartridges, then check to see that those little cogs keeping the paper in place are'nt oily or jammed, If worse comes to worse, take it to a curcuit city or a geek squad.
Aug 19, 2008 | Dell Inkjet 720 Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Lexmark E330 Laser Printer Logo
476 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
