Question about Intel Motherboard
Post Codes Can anyone tell me where I can find the post codes to a 1Bit NF8-V Motherboard? I looked all over google and couldn't find them.
  • 2 more comments
  • Tim Kelso
    Tim Kelso Feb 26, 2008
    Never Mind, I solved the problem.
  • Tim Kelso
    Yes and Yes. But I already fixed the problem.
  • delmo1 May 13, 2008
    I show Hex post code 6d. I can't get to bios setup. could use some advice.
    r.nicolani@verizon.net
  • Eddy968 May 11, 2010
    Do you mean ABIT?
    Are you asking about "beep" codes, or HEX post codes?
    President:
  • 2,351 Answers
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
My computer beeps every now and then. What are the beep codes for this motherboard?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
here is a link tells you all beep codes
http://www.computerhope.com/beep.htm
hope this helps you
Sep 10, 2011 | Gigabyte GA-EX58-UD3R Motherboard
1 What are the POST ErrorBeepCodes-2 Key sequence to eneter SETUP
Do a google search on Bios Beep Codes for the first, and to enter the BIOS setup, most PCs use the DEL key during the self-test. Some others use the F2 key. Most detail that, on the bottom line of the display during the post sequence.
May 07, 2010 | Intel Motherboard
Doesn't turn on, Mute and 2 volume lights constantly flashing
Your Pc motherboard is faulty, have a system engr look at it for possible reapirs." it won't boot ecept it is work on. Good luck
Feb 07, 2009 | Dell Computers & Internet
My pc won't start after I reset the cmos it only says beeb all the time over and over again. i can't find the manual to find out why it says beeb. the motherborad name is: ca63-sn rev. a1
The beeb you are hearing is a code being sent by the motherboard specifically the chipset on the motherboard. Count the beeps and go to the maufacture web site and look up the BIOS beep code that the manufacture uses. It will tell you what is wrong with the PC motherboard. My guess is obviously a hardware issue possibly the power supply is not working correctly and the motherboard is shutting down to protect itself. Good luck
Robert Matheson
Jan 03, 2009 | Computers & Internet
Intel Motherboard Logo
74 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
