Question about Samsung TXP2675WH 26" TV
Tv wont turn on
I turned off the tv now it wont come back on and has a thin green line crossed the middle of the tube. no sound out of speakers only a clicking noise from the rear of the set
    Scholar:
  • 135 Answers
Hi There!
Sounds to me like a frame collapse. Not familiar with this model though. My guess would be that the frame IC is faulty. This could be from over voltage from the supply side, Line Transformer which is arcing or just a general vertical amp failure. I would try replacing the caps in the power supply first and then the IC. Cheap enough to try. If all else fails refer to a repair technician. The Line Stage may be at fault. Good Luck, JUS004
Posted on Feb 26, 2008
1. My Sony KP-57WS500 TV is turning blue after abut 3 minutesof operation. It stays that way for about 30 miunes and comes back with pictures again, but with predominatly blue color. 2. Sometimes the TV...
Sounds like the picture tubes are failing,common on sony. do you notice any thin horizontal lines? You mite get lucky and be able to adjust the voltages. Remove back cover and look inside to see which tubes are lighting up.The front panel below the screen will come off and behind it is a small access cover.remove it. there you will find the voltage controls (its a plastic square with 6 knobs). 2 knobs for each tube, 1 is focus the other is the voltage labeled "screen". they are marked so look closely. Green is always in the middle but sometimes they flip the controls for red and blue so pay attention to which you are controlling .slowly adjust screen voltages to see if you can get it to stay on. If you over do it those thin horizontal lines will pop up and the tv will shut off again. If you already have lines back off the voltage by turning knob to the left slowly until they diappear. If that seems to fix it but the problem but it comes back later, then the tubes are shot. good luck!
Jul 05, 2010 | Sony KP-57WS500 57" Rear Projection...
Retrace green, relay on/off..when turn on the screen is green and after a few seconds it turns off by itself
Oh dear ! I fear my answer may not be what you want hear but my advise is free. Bright green raster with Flyback (retrace) lines may indicate a heater cathode short in the tube (crt) this causes a sharp increase in beam current and the power supply shuts down into standby mode. To prove the point isolate the red and green cathode pins on the tube base and cross couple the red video output stage to the green cathode pin and the green output to red cathode pin using wire links. If set now comes on with bright red raster the fault is in the green video output stage and not the tube. If still bright green then tube is most likely cause. Gently tapping the tube neck may prove the point, but take care the tube neck is thin glass and if hit too hard will break compounding your problems. WARNING if you do not feel totaly confident to attempt this level of repair there is no shame in seeking the advice of your local service technician. Safety first always
Mar 04, 2010 | Sanyo 21MT4 21" TV
First the tv would turn on with sound,but the screen would be black with a thin line in the middle.Now it will turn on and turn right back off in a tenth of a second.
This symptom is typical of a problem with the High Voltage circuit used to drive your TV CRT tube: this area cannot be fixed by your normal home user as it involved lethal voltage and current!
Feb 25, 2010 | Televison & Video
Green line in middle of tv when switched on
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Jul 15, 2009 | Panasonic Televison & Video
I have a Sony KP-57WS500 and there are arched, thin, and horizontal lines that appear.  Where could I find agreen picture tube or can I adjust the voltage myself?
Remove the front speaker grill and you will find an access panel (2 screws are hidden behind 2 little plastic caps at very bottom of speaker grill,just pop uot to access screws) .Remove the panel and you will see the picture tubes.In the middle you will see a little black control pack with 6 little knobs.The 2 in the middle are the green controls.They will be labled screen and focus.You will have to look hard for which is which.There may be glue over the controls if so just remove it.Slightly rock the screen control back and forth to adjust retrace lines out.If the unit shuts down during this process back it off a little and turn the set back on and proceed.
Jan 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Tv problem
bias on green is too high or current is too high^^^turn bias down on focus block^^^--curved lines(not retrace lines) convergance IC`s going or resistor(s) out of range^^^replace them^^^
Sep 10, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Green picture with horizontal green lines...
John,
First, Id like to know how old is your unit? Also, the lines indicates in issue with regards to the lifespan of your tube. The dominant green color has something to do with a malfunctioning ray gun of your tube. However, i had encounter a unit that was resolved by simply resoldering the circuitry of same problem.
Why dont you try to resolder the board first.
Response is highly appreciated.
chris
Mar 29, 2008 | Toshiba 32AFX61 32" TV
10 yr old emerson tv
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Feb 08, 2008 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Samsung TXP2675WH 26" TV Logo
78 people viewed this question
Jerry Greenberg
Jerry Greenberg
