Question about Brother HL-2040 Laser Printer
Paper stuck in Brother HL 2040
Please help me figure out how to get the paper out. Do I unscrew the top and lift it off?
Suggest you see the on-line manual (you may have downloaded it to your pc also as I did). It shows that you can open up the front and the back. If that isn't good enough...
1) if it is wrapped on the back, orange, roller, hold down on the blue 'tabs/levers' on either side of the orange roller to release the pressure so that you can pull it out.
2) you can pull out the toner and look in there (remember to press down on the blue 'tab/lever' before you pull the toner out by grasping it in the middle - the paper may be easier to see/reach that way.
Posted on Feb 28, 2008
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
How do you get the toner cartridge out of brother 2040? we have paper stuck under it
The toner and drum come out together, open the front door and pull the handle in the center straight out toward the front. The toner lifts off of the drum by pushing the blue lever on the right or left rear side and lift up and out. You need to inspect the underside of the toner and drum for paper scraps that could cause jams.
Nov 12, 2009 | Brother HL-2040 Laser Printer
FUSER TROUBLE HL 2040
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
I have paper stuck in my Brother HL-2040 but cannoy see it. How do I open up printer to get the paper out?
there should be latches on back side and on the bottom side of the printer. when you unlock it and open you will be able to see the paper.Usually if you open cover just as to remove cartridge you should see paper jammed
Sep 23, 2009 | Brother HL-2040 Laser Printer
Brother HL 2040 - Notecard sized paper jam (you responded)
Access cover is the cover where open to replace the cartridges , once you open that check for any paper stuck ....if still cant find carry with envelope procedure in the troubleshooting steps given earlier , Its place were we are ready to help people ......
Good luck....
Nov 26, 2008 | Brother HL-2040 Laser Printer
Printer paper is stuck in printer
There is a door at the back of your printer. Open it. Now there is a lever on the side which releases a second door. (It swings open from the top back.) Once open, you should be able to remove the remaining bit of paper.
(BTDT, had to figure it out the hard way.)
Jul 14, 2008 | Brother HL-2040 Laser Printer
Paper Jam
it maybe the paper......make sure your paper is laser print paper and right thickness....
Apr 30, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
