Question about Toshiba MV-13N3 Television
Bad sound there is a crackling sound, poor speaker sound. Has always sounded find. i have direct tv and there is on interference. picture is great
  • 280 Answers
First thing would be to change the speaker. look at the back of the speaker and it will have 4 or 8 ohm rating replace with one of the same ohm and size from Radio shack. around $6 -
$9 if the sound still is a problem it will be the audio output IC
Posted on Mar 10, 2008
No sound picture is great
on the main avi board there is a series of capacitors check these. if you have the tv on and have the sound up on full do you hear a humming sound ? or a crackle sound. also try the external speakers out you will need to change the settings on the tv menu to activate this and try some computer speakers on them see if this side of the audio board is faulty as well.
Aug 27, 2013 | Toshiba 52HM95 52" HDTV Projection...
The sound on my Dell W4200 is crackling some times even when the sound is on mute. Sometimes the sound is fine, other times no sound and other times the crackling noise. Any idea what problem may be?
Hi There,
Crackling sound is often an indication of bad connections to the speakers. Are you listening with the built-in speakers or through an external amplifier?
If you are listening through an external amplifier or speakers, check all of the connections to make sure the cables are properly inserted, and wiggle the cables from each end and the middle to see if that reproduces the symptoms. Sometimes a cable can become damaged from being squashed or bent, and it may be as simple as replacing the faulty cable with a new one.
If you are listening with the built-in speakers the situation might be harder to identify and correct. Sometimes it is as simple as nearby wireless devices or radio towers causing interference with the speaker. You can try repositioning wireless devices such as computer routers, cordless landline phones or radios to see if that helps.
However, over time the solder used to connect the internal components can wear and sometimes break the connection. For this type of situation repair is usually the only option. If the warranty of your TV has expired you may have to take it to a local TV service center. Typically a loose solder joint is easy to identify and fix, so the repair bill should not be high.
Please post back with your results.
May 26, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Crackling sound
Have you tried some headphones directly into the headphones socket? Does the sound still crackle? Usually 'crackle' is associated with dodgy leads and you will be able to hear the lead responding to movement by crackling more, a hissy sound often means that there is a fault with the socket and sometimes removing and reconnecting the jack into the socket a few times will help this. If it sounds like hiss with little pops it's usually electrical interference and could mean a bad earthing in the circuit somewhere
Jun 06, 2010 | Dell (8H390) Sound Card
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Speaker interference
you should be able to disconnect the analog audio cables from the cable box and Denon, with the HDMI connected, press the input mode button on the front left of the reciever to select auto and that should fix the issue
Feb 01, 2009 | Denon AVR588 Receiver
Toshiba tv making crackling noises
Is the sound coming from the speakers or from inside the tv, like an electrical arc? It could be the high voltage wire going to the picture tube. Do not attempt to test this yourself as there is many thousands of volts on that wire even when the tv is turned off. That wire attracts dirt that may be causing it to arc.
Jan 28, 2009 | Toshiba Televison & Video
Sanyo 24inch TV
Sounds like you have a bad speaker,or at the most the audio amp needs changing. Get old speaker out of another tv or stereo.
Oct 04, 2007 | Televison & Video
Sound interference
As you there seems to be interference via sound as the picture is fine. the interference is a crackling noise& tv is old 1 CHECK SPEAKER 2 so in that case tunning in sound section is disturb get it tnnned. 3 any components in sound section has done defective(SIF)SECTION. 1 CHECK SPEAKER not matching or paper torn or paper cone hard.
Sep 17, 2007 | Televison & Video
Abnormal crackling sound from speakers
check the Audio if ic or something gone bad around it. good luck
Apr 28, 2007 | JVC AV-27730 27" TV
Toshiba MV-13N3 Television Logo
144 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
