Question about Logitech LX7 Cordless Optical Mouse
Lx7 mouse problem
New Mouse, new batteries. Cursor keeps getting stuck and won't move. Have receiver plugged into USB port on LCD monitor ports. Running Windows XP service pak 2. HELP!!! This is my Wife's buisness system and she is not able to work well with this problem.
  • 2 more comments
  • happyfarmer Feb 27, 2008
    Seems to be fixed. Receiver was near iPod. I attached the extension dock that comes with the mouse to the USB port on the monitor and put the receiver away from the iPod. Mouse is now working w/o problems. Will monitor this situation for future problems.
  • bojang Mar 03, 2008
    I have a simmilar problem but with another model (LX5). At one point the mouse stopped to react on movement although the mouse buttons including the scroller are working properly, I tried changing the batteries, unplugging and then plugging the mouse, resetting, cleaning the bottom, but nothing helps.
  • jmarie49 Jun 10, 2008
    We have a brand new mouse and reciever for our desktop. The wireless reciever is a "fast rf wireless mouse reciever". The set worked for a day and now the cursor wont move at all. I tried unplugging the reciever, switching the batteries and turning the mouse and the computer on and off several times to no avail.
  • djas Jul 20, 2008
    bought a Logitech LX7 on EBay from Justdeals.com. Invensted several hours to make it work. no success. Had same problem and 1 more problem that the green power indicator was also not working. Still following up to get it replaced.
Ok i bought the logitech lx710 keyboard n mouse set
the mouse sort of works...i can click, scroll etc...but the cursor just WONT move
iv updated the drivers, tried re-syncing the mouse with te receiver
used new batteries....nothing seems to get this mouse to work!!
Posted on Nov 01, 2008
Batteries fools
Posted on May 31, 2008
How to install 2.4Ghz wireless mouse with USB receiver?
Insert the batteries into the mouse. Turn the mouse over, find the battery cover, and slide it off. Insert the appropriate batteries-usually two AAs.
  • The wireless receiver that plugs into the computer uses USB power, so it needs no batteries.
Connect the receiver to the computer. If your computer has a USB port (as most do), plug your receiver into an available port. There will also be a green adapter supplied, in the event that your system requires the use of the mouse port. Caution-don't try and force the mouse adapter into the keyboard port!
  • The mouse receiver has a USB plug (left), but can also plug into the mouse plug through the adapter it came with (right). If your receiver plugs into the USB port it should look like the left. If it plugs into the mouse plug it should look like the one on the right, only connected to the receiver.
Connect the mouse to the receiver. Place the mouse in close proximity to the receiver, and note the following:
  • The receiver should have a visible button that is easily pushable by the average human finger.
  • The mouse will usually have a very small reset button in a hole on the bottom that can be pushed by something like a pencil or paper clip.
  • Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
Find a permanent position the receiver. Place the receiver where it won't be far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk.
  • The furthest a wireless mouse can get away from the receiver and still function is about 9 feet (2.7 meters), so keep that in mind.
Test your new mouse.
  • If you plugged into the mouse port, restart your computer.
  • If you plugged it into the USB port you should be able to use it immediately.
  • When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Adjust your mouse settings. Use the control panel that came with your wireless mouse, or download the necessary software from the manufacturer's website. Adjust the settings so that the mouse performs as you require.
Oct 18, 2014 | Computers & Internet
How do I get the mouse to mouse the mouse cursor
the battery in the mouse makes the red light come on, not the operating system.
Look in Device manager,find the mouse, uninstall the drivers, scan for new devices, re-install the drivers.
Otherwise look for new drivers on manufacturers site.
Apr 13, 2014 | GE 98566 98566 wireless optical mini mouse
My cursor is stuck in the middle of my screen on my computer, my mouse is wireless so i tried changing the batteries and using every USB port and still nothing. I then got a wired mouse and tried that in...
Sounds like USB stopped working(maybe driver related). Try booting into safe mode by pressing f8 at startup before the logo screen for windows appears. If it is working in safe mode then it is not hardware but rather driver related. This also sounds like an older computer that might have a ps2 mouse port. If you have an old ps2 mouse you can try that.
Aug 14, 2017 | Microsoft Comfort Optical Mouse 3000...
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
Hello how do i get the wireless mouse to work on my laptop? i have it plugged in but it doesn't work
1. Put in the batteries Find the battery cover and slide it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
2. Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
3. Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily pushable by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
4. Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without not working very well is about 9 feet (2.7 meters), so keep that in mind.
5. Test your new mouse.
- If you plugged into the mouse port, restart your computer manually.
- If you plugged it into the USB port you may begin using it.
- When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this help. Goodluck!
Mar 27, 2011 | Computers & Internet
I am trying to hook my mouse up to my new laptop but I can't get it to work. Please help.
1.Put in the batteries Find the battery cover and slide it off. Insert the appropriate batteries.
2.Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
3.Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily pushable by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
4.Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without not working very well is about 9 feet (2.7 meters), so keep that in mind.
5.Test your new mouse.
* If you plugged into the mouse port, restart your computer manually.
* If you plugged it into the USB port you may begin using it.
* When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
This should help you to fix the problem.
Mar 03, 2010 | Logitech Cordless Mouse
Fairly new mouse (new batteries also)not working. Solid blue light when plugged into USB port but cursor will not move at all when click mouse buttons or scroll bar. Rebooting system nor unplugging USB...
First make sure your mouse is installed properly. Go to Device Manager and see if it lists the mouse and has no conflicts. Also, try a different USB port, especially if it doesn't show up. If your receiver and mouse have reset or connect buttons on them you'll need to push those also. try alternate batteries. if none of these suggestions can solve your problem you may be looking at a defective mouse.
Nov 05, 2009 | GE Optical Mini Wireless Mouse 98793
It not working, put new batters in. it is also plug in the usb
After a battery change you must re-sync the mouse to the receiver that plugs into the USB port.
Oct 15, 2009 | Logitech LX7 Cordless Optical Mouse
Receiver light is steady green. mouse won't light up. cursor won't move.
Why don't you try at the moment of placing a new battery to see if the small button that protrudes, where the receiver is located at the bottom of the mouse is pressed down. Without the receiver in place that **** on must be out for as long as the receiver is in the USB port.
Good luck!!!
Chawah.
May 19, 2009 | Microsoft Wireless Notebook Optical Mouse...
Logitech LX7 Cordless Optical Mouse Logo
327 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
