Question about Hoover 24 in. DT999 Free-Standing Dishwasher
GE Dishwasher GSD3404G top arm won't spin
Our dishwasher isn't cleaning our dishes very well, the glasses on the top come out grainy. When I started the dishwasher yesterday it seemed to be taking a really long time to fill and start washing, eventually it did start but again the glasses came out dirtier than when we put them in. The upper arm is not spinning so I don't think the upper rack is getting rinsed. What could cause the upper arm to remain motionless (I have already taken it off and cleaned it)? The dishwasher used to work just fine and the water heater has not been turned down. We have hard water but not really hard and I think I put in the correct amount of detergent. Also there is a smell, like stale water whenever we open the dishwasher.
Thank you
  • raferob Nov 29, 2008
    The top arm of my G.E. dishwasher will not spin. All the glasses on the top rack come out dirtier than before. I found a piece of paper in the tube but it stilldoesnot move.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Www.dishwasherfilter.com will solve this problem immediately. check it out.
Posted on Aug 23, 2009
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
We have had this dishwasher for approximately 2 years. Dishes do not clean well. For example, I put a mixing bowl in that I just mixed brownie in--and the bowl did not come clean (simply a thick...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 01, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Food is being left on dishes, not cleaning well. Residue on glasses and pans(white) You can feel a grainy residue on cups and bowls
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 23, 2011 | KitchenAid Dishwashers
We have a built in GE dishwasher. It has worked fine for about 4 years but now the glasses in the top rack will not come clean. I have cleaned all the holes where the water comes out but I think the...
Dishwasher
How to Buy
heatman101
Dec 13, 2010 | Maytag Dishwasher
Dish washer does not clean dishes very well and leaves a grainy residue stuck to dishes
Dishwasher
How to Buy
heatman101
Nov 30, 2010 | Bosch Evolution 500 SHE45M06UC Built-in...
My dish washer is not washing the dishes on the top shelf and leaves a sand like residue on top of the cups and glasses. I have washed out the top spraying arm and washed the dish washer out with vinegar.
Dishwasher
How to Buy
heatman101
Oct 01, 2010 | Zanussi 24 in. DA6141 Built-in Dishwasher
GE Quiet Wash 3, top arm does not spin
It sounds like you don't have enough water. Your water inlet valve may be not letting in enough water or the plastic pump inlet screen located on the bottom of your dishwasher had something blocking it.
  1. Check to see if there is something blocking the plastic screen on the bottom of your dishwasher.
  2. When your dishwasher is in the final cycle add a pot of hot water to the dishwasher and see if your dishes come out cleaner.
If the dishes come out cleaner you may need a new water inlet valve.
Dec 29, 2009 | General Electric Adora GHDA670N Built-in...
Dishes and glasses on the top rack aren't getting clean. Soap left in dispenser cup after cycle GE PDW8200
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
i
May 02, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Hoover 24 in. DT999 Free-Standing Dishwasher Logo
879 people viewed this question
Top Hoover Dishwashers Experts
Jose Pino
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
