Question about Saeco Magic De Luxe Espresso Machine
Reservoir empty tank lights up but tank is half full of water
Not a major problem but red light pops up and I have to refill the reservoir tank even though it is still 2/3's filled. Any ideas? Thanks
  • 2,039 Answers
In the water tank you have a little magnet that magnet need to move up and down shake the water container to see that magnet move .thanks for using fixya
pierre
Posted on Feb 27, 2008
Why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
May 31, 2014 | Miele Coffee System
Red light flashing even though water tank is full
try to check the floating magnet inside of reservoir tank.
Nov 06, 2012 | Sunbeam Cafe EM6910
I have a Zanussi Electrolux TC7103W condenser drier and for some reason the empty water light keeps coming on even though the reservoir is usually only half full. I have tried emptying it and tried un
Make sure lint build up is clear behind condenser
Sep 29, 2012 | Dryers
The tank empty light won't shut off even with water in the tank.
The float valve is probably stuck. Empty the water out of the reservoir and clean the tank with 50/50 White Vinegar and water.
Feb 09, 2011 | Sunbeam 1117 Humidifier
When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Apr 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Not enough water making it from holding tank to dispensing cup
your machine is "Short Cupping"
It needs to be descaled. Even though the descale light might not be on yet, the descale light only comes on when it is in SERIOUS need of a descaling. You should descale once every 3 months.
Fill reservoir with distilled white vinegar and leave the machine on for 4 hours (make sure to turn off the auto off option).
after 4 hours, run the vinegar through the machine until the reservoir is empty. Refill with water and repeat twice. you will notice a difference right when you start running vinegar through.
Apr 04, 2010 | Keurig Elite B40 Coffee Maker
My salt light won't stop flashing even though its full of salt. Its a Hotpoint FDW60. Ive tried turning off and an at the mains.
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
AcmeUK
Oct 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Tumble dryer not working
Spoke to my maintenance engineer at work and he said that most of these appliances work by using float switches. After stripping down and drying out the previous day decided to refill reservoir with water and letting drain back in refilled again 15 mins later till no more water could go back in. Then emptied water reservoir and let the water drain back out into reservoir. Think this must have dislodged the float switch and all seems back to normal.
May 25, 2009 | Electrolux Dryers
Matsui mf160 dishwasher salt indicator will no go out
AcmeUK
Apr 20, 2009 | Dishwashers
Empty light on espresso machine won't turn off and tank is full
I have the same machine. I just went on the coffee geeks website and it is easily solved. Just add a few grains of salt to the reservoir - the sensor cant detect water that is purified - strange but true as four grains and it fired up just like that.
Apr 13, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Saeco Magic De Luxe Espresso Machine Logo
488 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
