Question about Acer Aspire 5100 Notebook
Broken connection on power jack
I could resolder the bad connections if I could get this acer zl5 apart. can you help me?
  • rftrap Mar 01, 2008
    Thanks so much for the info. It did help us get the laptop apart. We got the power jack fixed but the laptop still wouldn't come on. It does have a flashing light on the front of the unit thats all. any other ideas? Thanks Steve
    Sergeant:
    Champion:
  • 244 Answers
For Aspire 5100
follow this step.
from backside
1. remove battery
2. remove hard drive cover and hard drive
3. remove the thermal cover, remove wireless card and antena cable.
frontside.
1. remove the power button cover.
2. remove keyboard.
3. remove lcd cable, wireless antena.
4. remove the lcd screw (2 long screw and 2 short screw)
5. remove the lcd screw from the back side (2 short screw).
now the lcd is separated from laptop body.
from backside again,
1. remove fan, there are 2 screw that hold the fan
2. remove heatsink (4 very short screw)
3. remove all screws from backside, there is 1 screw hidden "under" heatsink. it's short scew (longer than heatsink screw).
from frontside, remove 2 screw on top part of the laptop body.
and than you can remove the uppercase now.
after you remove the uppercase, remove 2 screw that hold modem, and remove 1 screw (very short) on bottom part, it's close to touchpad button. remove power switch board and modem and then remove the speaker cable and mic cable.
that's all you can take out the motherboard.
note: just remember to use the correct screw when you put it back.
i hope this will help.
Posted on Feb 27, 2008
Acer 4320 won't power up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test your acer travelmate 4320 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Dec 12, 2012 | Acer TravelMate 4320 Notebook
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Possible causes:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Aloha, I plug the power cord into my computer and the end that actually goes into the comp sometime registers and changes and other times it doesn't. Right now I cannot user my Acer because my...
I'm assuming this a laptop computer and you are having problems with the AC power adapter jack. This is quite common. Often the solder connections securing the jack to the circuit board inside the computer crack, or the contact lugs on the jack itself break. If the problem is a cracked solder connection, the fix is a simple resoldering job (the primary expense is labor to get the board out for repairs). If the jack is broken, it can be replaced - it will be about the same as resoldering plus about $1-$5 for the part.
Sometimes the problem is a broken wire right at the plug on the AC adapter. If it is a standard plug, that can be replaced. If it is an unusual custom plug, you're stuck with replacing the adapter.
To prevent this problem in the future, always hold the plug when you remove it from the computer (never yank on the wire), be sure you insert it straight into the jack when you plug it in, and avoid off-axis stresses on the plug or the cable near the plug.
Jul 10, 2011 | Acer (56.04145.901) (5604145901) Power...
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
A bad connection between the power jack and the
What needs to happen is on the motherboard underneath the power jack, there are solder points that have hairline cracks in them. The best way to fix it is to remove the motherboard from the laptop and to resolder all the solder points for the power jack.
Once you do this then the power should stay on cause wiggling the power cord won't cause the laptop to turn off.
Aug 10, 2009 | Toshiba Satellite A205-S4707 Notebook
Ac adapter sometimes works for a few seconds not at all
It most likely has some broken solder connections on the jack. Unless you have soldering equipment there is nothing you can do yourself except to take it to a repair center. If you tell them that the A/C adaptor jack has some broken connections that need to be resoldered, they may give you a break on the normal repair cost since this is not a big job. It just requires the right tools. If you have the soldering equipment you can take it apart and resolder those connections on the jack yourself.
Dec 04, 2008 | Televison & Video
Dismantle to resolder coose power socket
I would either look on youtube or Acer's website to find some kind of service manual which would help you. Make sure to keep track of your screws. :)
Nov 01, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 3610
The problem is that the power inlet jack has a bad connection on the motherboard. The way to resolve this is to remove the motherboard from the laptop and resolder the jack. This is not a repair I would suggest for the novice. If this is not repaired soon, further damage can be done to the motherboard that may not be easily fixable. Please have this repaired soon.
Dan
May 29, 2008 | Acer Aspire 3610 Notebook
Worn power connection
Well, if it's just the soldering points that are weaking then you don't need a new one. Just resolder those points (probably won't even take any extra solder but i would recommend giving it a little more so it doesn't just break again) and you should be fine. If the actual jack is damaged then you'll have to replace it. No real ease here, though, as you'll have to take the laptop apart either way.
May 20, 2008 | Dell Inspiron B130 Notebook
Acer Aspire 5100 Notebook Logo
249 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
