Question about Sanyo DS31520 31" TV
High pitch noise
A high pitch noise comes from the back of the television now and then. If I rap the top or side of the tv it stops momentarily. It seems to be happening more frequently.
  • SAMTER Feb 27, 2008
    What would you expect the cost of replacing the flyback transformer to be?
    This is a tube type TV
  • 2,336 Answers
The high pitch noise is most likely produce in the flyback transformer due to loose windings inside it, so when you move it or tap it on top; the high pitch noise stops momentarily.
The only way to fix it, will be replacing the defective component. I would suggest to take it to a repair center because you will be exposing yourself to high voltage and need to be be careful when working around it.
If the noise is being produce by the picture tube, is not worthy to fix the TV as the price for a new CRT is very high and you may as well buy another TV.
Posted on Feb 26, 2008
  • Jaime Hernandez Feb 27, 2008
    A reasonable cost for a repair is about 1/3 of what you paid for the TV. Depending how old is the TV, you may want to consider the cost of the repair because pictures tubes have a life expectancy of about 8 years.
    Hope this helps you to make a decision.
    Scholar:
  • 121 Answers
Sorry to hear about your issue, let me see if I can help.
What type of tv is this? tube or flat panel? If tube, have you recently moved it and shook it up a little?
If panel, are you using an hdmi hookup or just regular cable from a cable box?
Be sure that your hookups are on tightly and that your cables are not tangled as well especially hdmi cable. Let me know if any of this is helpful in solving your issue or if I can be of more assistance. Once you respond I can help more, just need more information..
Thanks,
d
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
High pitched noise from inside the TV when picture comes on
Hello randapaint,
This might be from the IHVT (Integrated High Voltage Transformer), or more specifically a short in the IHVT causing it to arc, producing the high pitched whine, you are hearing. Take the back off of the TV and try to detect where the sound is coming from, more then likely you will notice it coming from the section that contains a large component with a large red cable coming from it, to the top of the CRT (picture tube). Replace the IHVT (with the exact same model) if it is bad.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 07, 2009 | Televison & Video
High pitch noise from the flyback
You can tell to some extent what it may be by listening carefully and trying to identify the location. If you, remove the back cover of the set; stay away from danger, just listen to where it seems like the sound is coming from. If it is coming from inside the high voltage cage it is the flyback. If coming from around the main power transformer it is one of the power supply parts.
Please Rate This Fixya solution
Jan 23, 2009 | Samsung HL-P6163W 61" TV
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
High Pitched Noise
most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise continue.you will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Jun 11, 2007 | Toshiba 27A41 27" TV
High pitch noise
what you are hearing is the mechanical vibrating of coils & or transformers in the tv. 1st and easyest is to hot glue the parts that is making the noise down. if that does not work, removing & reinstalling the part is next. the last is replacement. the most likely parts causing is the 1. horizontal linearity coil, 2. the run or switch mode transformer, or 3. the flyback transformer. good luck.
Jan 09, 2007 | Zenith C27F33 27" TV
Sanyo DS31520 31" TV Logo
142 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
