Question about Mitsubishi VS-45607 45" Rear Projection Television
TV screen jumps and rolls, sometimes won't stay on
After moving the TV here, very seldom do I get a clear picture. The screen just jumps and rolls all of the time. It is very hard watching the TV and forget about reading anything on the screen. The television is about 10 years old.
  • Mitsubishi Master
  • 8,617 Answers
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Posted on Feb 27, 2008
I have a westinghouse tv, model ltv27w2 and the picture is clear but it rolls and jumps constantly. any ideas on what part to replace?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 16, 2016 | Westinghouse Televison & Video
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi Vs-60705 Bigscreen turn on vertical roll warms up stops rolling and begins jumping up and down also picture is not clear
Check C2P05[ location on convergence board]. This is a 16volt 100Mf cap that is bad. And check out C2V29 [cap value is 16volt 22 Mf.] And still while you're at it, resolder the pins on the convergence ICs.Should fix your TV!
Nov 29, 2009 | Televison & Video
32in Westinghouse lcd / picture scrambled
my westinghouse has the exact same problem....i have noticed it will catch sometimes when the screen changes from one picture to another that is totally different and one right after another......
Jun 30, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
TV Picture problems
replace all caps in vertical area, if problem stays, try replacing pumpup diode and vertical. if still same problem check drives goin to the vert, and vcc goin to it.
Apr 09, 2008 | Televison & Video
Westinghouse 27" lcd hdtv
My Wesinghouse 27" lcd hdtv jumps and vertical hold is out of control after being on 15 mins. The cable company checked the connection and it is clean. We did not damage the tv. It has been doing this since we got it. We did not get a service contract. Sometimes the screen goes black with a small rolling picture on top. Help me please. Can the maufacter still help us?
we lost all the papers when we moved.
Jan 27, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Picture has horizontal lines that move to middle of screen........
Just got this fixed. The problem is the 21 (yes, 21) main capacitors. It'll only get worse if they aren't replaced. The whole screen'll start jumping, multi-hour "warm up" times until you get a clear picture, maybe not even then... it isn't pretty. Just nip it in the bud now, and more power to you if you tackle it yourself. A good repair shop ought to be able to do this for under $400 if you can't.
Nov 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
154 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
