Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Xboxlive on netopia 2247nwg
I have the netopia 2247nwg and i cant connect to xbox live... ive opened ports and various other things as told by xbox support and still i have no luck
Have you tried http://portforward.com/ i've had alot of problems with this router fixed my xboxlive issues with portfoward but am having problems with my blueface voip
Posted on Mar 03, 2008
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
Trying to set up xbox live for fifa 12 unable to get connection from internet to xbox live telling me I need to open several ports etc.Can anyone help
Hello
Check with your router manufacture on how to log in to the router.
Once you have logged in,check that upnp or universal plug and play is checked to on.
This should allow x box to work through the router.
Oct 11, 2011 | Netopia 2247NWG-VGx Wireless Router...
I need to make sure port 3074 is open for xbox live but dont know how to do it.
You can use the netstat -a command to find out which ports are open on a local Linux/Unix or Windows system (Figure 1), but netstat can't be used remotely across a network. netstat.gif
FIGURE 1: The netstat command can be used from the Linux or Windows command line to check on
open ports on the local computer.
If 3074(TCP & UDP) port is not opened on the router, refer: http://www.netopia.com/support/hardware/technotes/CQG_025.html for further step-by-step assistance.
For any further help/support, revert!
Thanks for asking..
Arvind S Iyer
Sep 26, 2010 | Netopia 2247NWG-VGx Wireless Router...
I am trying to get xbox live working on my xbox 360 console but I need to open some ports and I dont know how , how do I open the ports ? I need to open the port 3074 and I need yo use (UPnP) because I...
Okay so Here is the very simple solution. Go to your router page (192.168.1.254) and select Custom Services. Delete every port opening service you have made. Then Define a Custom Service lets just call it Xbox A and Open ports 80 - 65535 for TCP with the base host port 80 Do tthis twice for both TCP and UDP options. Enable the services on your Xbox (It needs to be Connected and have a static IP adress) It can take about 15 minutes to open all the ports to be patient. Your Xbox also needs to have a static IP adress. Lastly set the routers firewall on low and give it a shot. It worked for me!
Jun 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
Cant connect to xbox live
make sure that your xbox is acctually getting an ip address, by default it should be a 192.168.0.xx number and the gateway should be 192.168.0.254
If however your xbox tells you that its ip address is 168.xx.xx.xx (a private ip address) or if it is simply 0.0.0.0 it would sugest a cabling problem.
However if the network troubleshooter finds no faults and you are still unable to get into xbox live try setting up a PPPoE connection using the username eircom and broadband1.
Alternatively,If you click on Firewall in the Netopia admin page, and set the security level to Low, xbox live would suddenly start to work.
******Also add UDP ports 88 and 3074 if nothing works.On a netopia 3347 you can get this option in the NAT option.U have to enter the port numbers and the service name(xbox).
Hope it works for you.
Apr 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Xbox live
your xbox should work using your netopia but you need to setup some settings. click here on how to.
hope this'll help you
ciao
Sep 28, 2008 | Netopia 2247NWG-VGx Wireless Router...
Opening nat
You just need to enable port forwarding for the ports that the xbox live is using, specifically these ports:
UDP 88
UDP 3074
TCP 3074
You then assign a the static IP you have set on your router, subnet, gateway and dns on your xbox and that should allow your xbox live to work properly with your router.
Aug 21, 2008 | Computers & Internet
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
199 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
