Question about Yahoo YHT-630 System
LAn then Dial UP
Hi - from office it is Firewall with Proxy ,now at home ,tried to click no Proxy but no avail .
Yahoo Mess closes automatically ,ver 8.1
Hi, I went to msconfig sys config utlity and disable all non microsoft sevcs and startup. After I unistall mc afee and replaced with symantec.
Im on line now using win messenger and yahoo messenger without hassle.
Thanks and More Power
Posted on Feb 27, 2008
Nu merge
HI, Please Follow these steps to configure your connection:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct.
i hope this will be helpfull to you. PLEASE DONN'T FORGET TO VOTE ME. GOODLUCK.......................
Jan 21, 2011 | Yahoo Messenger
Problem sign in
hi,
I HOPE THIS WILL BE HELPFULL TO YOU. PLEASE DON'T FORGET TO VOTE ME
Yahoo error 81003016
Open up your Internet Explorer
  • Click Tools>>>Internet option>>>Connection tab
  • Under Dial-up and Virtual Private Network setting
  • Double click your current internet connection that you are using now
  • Make sure that under Proxy Server, the 'Use a proxy server for this connection' is UNCHECKED
  • Now back to connection tab
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again
Sep 18, 2010 | Yahoo Messenger
Unsuccessful install of yahoo messenger
Try and install it again. If it unsuccessful.
you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:Click the Messenger menu in Yahoo! Messenger and select "Connection Preferences."
Click the OK button at the bottom of the window.
Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the OK button.
Aug 19, 2010 | Yahoo Messenger
Cant sign in in yahoo messenger at mozilla fire fox
Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the OK button.
Enable the "No network detection" option and then click the OK button at the bottom of the window.
After this steps and this still not solve it. You can check and set your I.S.P and Proxy Server. here are the steps.If neither of the above options work (sorry), you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:Click the Messenger menu in Yahoo! Messenger and select "Connection Preferences."
Aug 04, 2010 | Yahoo Messenger
Solution of error with yahoo 81003016
Click Messenger tab. Make sure the program window is open.
Then, click Connection Preferences. It will open up a window for you to work on setting up your connection.
On the Connection options, you can either choose:
1. Connect directly to the internet. (This is the recommended setting if you never had connection problems.)
2. Connect via a proxy server. (Use this option if you are behind a firewall and know your proxy server settings.
From the Internet connection option, you can choose among these three–Dial-Up, Broadband (DSL/Cable) or High-speed (T1/LAN). Once you’re able to select all your options, click Apply then click OK.
You may try switching connection from Connect directly to the internet to Connect via a Proxy Server and choosing HTTP Proxy then click Apply. This should work for you.
Good luck.
Jun 25, 2010 | Microsoft Windows XP Professional With...
Why i see error number 81003005 in yahoo messenger?
This message appear probably because of your computer proxy software by default change your connection properties.
Solution is
Open you internet explorer
  • click tools>>>Internet option>>>connection tap
  • Make sure that under Proxy Server, the ‘Use a proxy server for this connection’ isUNCHECKED
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again.
Jul 25, 2009 | Yahoo Messenger
The requested URL could not be retrieved
Hi Neerajsahu,
There are 2 things.
You either have a Permanent firewall or you have a proxy. If you know its a permanent firewall then you are pretty much stuck. But if its a proxy server there is a glimmer of hope.
Obviously the following instruction makes alot of assuptions on your network setup.
Assuming you have a proxy server, you could try going to the following place assuming you are using Microsoft's internet explorer.
Go to
Tools>Internet Options>Connections
Click on LAN Settings
Un tick "Use a proxy server for you LAN...."
Make sure you have ticked "Automatically detect settings"
Click OK
Click Apply then OK
and close IE and then Open IE again.
Now try and download the file again. If this still doesn't work then chances are you will need to see your Admin as they have a firewall appliance that checks everything.
IF the "Use a proxy server for you LAN...." was already unticked chances are you won't be able to get around it as you are downloading a file greater than 3Mb and again see your Admin.
If all else fails home and download your file that you need from there.
Hope it helps
Jan 02, 2009 | Computers & Internet
Login error 81003004 from Yahoo Messenger
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Dec 16, 2008 | Yahoo Messenger
81003004 problem
go click preferences->click connect directly to the internet (again..even though it has been already chosen)-> choose your connection and connect..i guess it will work..it worked for me..try it!
Nov 02, 2008 | Microsoft Windows XP Home Edition
Yahoo YHT-630 System Logo
76 people viewed this question
Top Yahoo Audio Players & Recorders Experts
Greg Ulan
micky dee
Kolbrun...
Are you a Yahoo Audio Player and Recorder Expert? Answer questions, earn points and help others
