Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Will not grab documents
The feeder on my HP Officejet Pro L7580 will not grab documents when faxing. I have to fax from the glass every time, but this is time consuming for multiple page faxes. I've tried cleaning the rollers and that did not work. What can I do?
  • llaw35 Mar 11, 2009
    Document feeder does not work. The solution to reset the printer did not work.
  • Anonymous Mar 12, 2014
    what to do with receiving a documents via fax that does not have the time and date typed across the top of the document.
    Sergeant:
    Champion:
  • 210 Answers
try this...
> unplug the power chord while the printer is turned on
> press and hold the # and 3 button on the printer at the same time and while holding it, insert the power chord.
> a semifull reset would be done
> after that try to fax.
thanks and regards
agnel
Posted on Mar 17, 2008
  • Tandesertman Feb 09, 2011
    The gears in the auto document feeder need to be checked and or replaced. The gears that turn the pick up assembly pivot back and forth to reverse the direction of the pick up assembly to either feed paper or lift up. There is a spring that keeps tension on them that likes to pop off. The document feeder needs to be removed from the printer to make the repair.
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
Paper jam cleared, now when trying to fax, will accept only about 1/4 page of the paper and sits there and spins something I can't see.
This link will take you to your users guide on the HP web site. Go to "Maintain and troubleshoot">"Clean the device">" Clean the automatic document feeder (ADF)".
It only takes a small piece of paper left behind, 1/4" square or less, to keep document feeder from working properly. GOOD LUCK!
www.hp.com
Oct 14, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Fax will only fax off glass. will not take
Isn't there a small electrical cable connecting the ADF (Automatic Document Feeder) to the rest of the machine? It is loose or disconnected.
Sep 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Faxing more than one page from glass.
You should be able to load the pages into the top "feeder" on the printer / scanner / fax. I think the needed to be loaded face up if I remember correctly. From there, you can dial the number, and hit fax, it should start to **** in the pages one at a time until they are all faxed.
Hope this helps!
Tim
Jul 12, 2009 | HP Officejet Pro L7380 Laser Printer
Paper jams when trying to fax or scan document
Check if the ADF backing is tucked under the the ADF frame. You can view here http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf steps 7 & 8 on page 155.
Apr 07, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
AUTOMATIC ORIGINALS FEEDER
I'm trying to print/fax several pages but the feeder doesn't "grab" the paper--basically nothing happens...BTW, mine is the HP Officejet Pro L7780 All-In-One.
Sep 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
Original Loaded
I just came across this very same problem today on my L7580 and I found that there is a spring loaded bar that flips down and makes a contact. When paper is inserted it lifts this bar up and tell the feeder that there is a document. If this is stuck in the upright position then you will always have the "original loaded" message and have your issue. Mine had popped out of its alignment holes and I had to snap it in and the whole thing worked like a charm!!! I hope this helps everyone else with this issue!!!
Jason Gray
Jul 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Faxing multiple pages
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
Jun 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
342 people viewed this question
Ben Johnson
