Question about Samsung RS2630SH Side by Side Refrigerator
Noise the refrigerator makes a loud rakeing sound. almost like a fan belt on a car when it's loose. i checked the book and it says to move away from wall or check for anything that may have fallen behind. neither works
  • 2 more comments
  • spike16 Mar 11, 2008
    Is the plastic fan assembly the condenser fan you are talking about? If so, I am having the same problem. Where did you buy the part?
  • mkleid Mar 15, 2008
    How do you remove the fan assembly from the plastic shroud? I can't figure out how to remove the cooling fan and fan motor to replace it, as it makes a squealing noise. Thanks
  • Derek B Mar 19, 2008
    I have a Samsung RS2556SH Refrigerator, and it started making that awful sound, and now the freezer temperature is at 72 degrees. This is my second Refrigerator from Best Buy, the first was brand spankin new, and it died the next day. The second Refrigerator worked for almost 1 year and a half. I know a little about Troubleshooting, since I work for AT&T for several years, I tested the freezer motor, I applied 12 volts to it, and seen it move.
    I measured the voltage from the molex connector, and got only 2 volts.
    Problem with the Frigerator voltage supply to the motor. The Schematics looks like a horror, but I can figure it out. Derek.
  • Anonymous Jun 22, 2008
    How do you change the condensor fan motor?
Remove back panel and take out the fan and oil the rod the fan spins on and it should fix it!!!
Posted on Jun 22, 2008
The condenser fan motor is the culprit of the problem. all u have to do is replace it with a new one it would cost about 60 dollars
Posted on Feb 27, 2008
    Problem Solver:
  • 5 Answers
You can check the fan and spray oil to the motor. Unplug the wire core out of the outlet on the wall. Then you can test the fan by spining it manually and listen to it carefully and you will hear the sound come from the fan. Right at behind the fan you can see a metal bar. Just spray the WD1040, which you can buy at Wal-Mart or any where at automative department.
I fixed mine and my friend Samsung RS2630SH like this.
Posted on Feb 08, 2009
What causes a squeaky sound from the engine of an 2000 Isuzu rodeo when engine is running?
it could be one of the belts. if you put a little wax or brake fluid on the belt in a couple of places and the squeak goes away then you either have a loose belt/s or the belts/s need replacing. if no change it could be the timing belt making the noise.
Sep 14, 2014 | 2000 Isuzu Rodeo
The engine in my automatic '91 Integra intermittently makes a loud squeaking noise...it sounds to be coming from the left side of the car under the hood. It is not the fan/fan belt, as the noise...
are you sure its not your fan belts? because if fan belts are not turning, it means that the engine is off. check if the tension in your fan belts are still ok. if not, have it re tensioned. if noise is still present, have it changed.
Aug 11, 2011 | Acura Integra Cars & Trucks
Have a 1995 ford heavy 250, 7.3 diesel, recently had fan belt replaced and now getting a loud high pitched vibration noise when accelerating it occurs between 1000 and 1500 Rpm and goes away at higher...
sounds like your fan clutch may be failing, remove the drive belt and manually spin all the pulleys by have listen for noise and feel for looseness in the bearings
Jul 31, 2011 | 1995 Ford F250
My 1997 Plymouth Breeze has a very loud screeching sound when I put it in Park or in Neutral. When I put it in gear it quits making the sound. when left in park it blows the fuse to the starter. I turn the...
Im hoping this is only a loose drive belt ck the belt tension by moving it up and down you should only have 1/4 play on the belt more than that you belt is loose
Apr 21, 2011 | 1997 Plymouth Breeze
When I start the car there is a loud noise as if a belt is turning and it needs to be lublicated. However, after the car has ran for a while the loud noise goes away but when I turn the wheel there is a...
Yes it sounds like your power steering belt needs changed also you need to check the power steering fluid and the tension of the belt whereas the belt might be loose. If this is accomplished via a belt tensioner then the tensioner probably needs replaced also.
Mar 12, 2011 | Nissan 200SX Cars & Trucks
Loud pop (sounded like a gunshot) during final spin cycle than heard constant noise. Does this sound like a busted bearing or belt? The tumble wheel is now very loose (easy to move and turn inside washing...
if the drum is very easy to turn with no resistance then the belt is likely broken and needs replacing. This is like changing the fan belt on a car where you loosen the bolts on the motor and hinge it towards the drum. Once the belt is in position, lever the motor back away from the drum to tension the belt and tighten the bolts.
Dec 17, 2009 | Frigidaire Washing Machines
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
If car is not warmed up, a loud squealing noise is heard for about 20 seconds
Does it sound like a fan belt ?
Belt(s) could be loose and or warn..
Check you belts..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | 2000 Oldsmobile Alero
91 buick regal 3.8L is making a loud clank noise in belt area
It sound to me like you have a bad belt tentioner check to see if it's real easy to move by hand if so change it problem solved .Hope this helps you out!!!
Jun 03, 2009 | 1991 Buick Regal
Squealing NOISE possibly from fan belt
If the noise going away every time u turning off the ac it's probably your ac compressor belt.however i will suggest to take some vaseline and rub it all over the exposed parts of your drive belt.
Jun 22, 2008 | 1998 Dodge Caravan
Samsung RS2630SH Side by Side Refrigerator Logo
371 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
