Question about Whirlpool GHW9400 Front Load Washer
Ccu and Detergent Yikes
Well, i come back from an extended trip to find out that my roommate, took off the cover of my duet, to check the wires on the ccu. It was having the F/dl code. Well the Smartie, hit his head on the shelf above the washer, and dumped over a gallon of detergent into the uncovered machine. Looks like the CCU fried a resistor, he said it the CCU smoked. Just curious if anyone has any pictures of the full CCU board, and Pictures of where all the wires get pluged back into, to make the install of a new board easier. He failed to do that, and has no idea where they all went.
  • Gary Davd
    Gary Davd May 11, 2010
    the wires only plug into the correct connectors there is no way you can put them back on wrong here is how to replace it
    REMOVING THE
    CENTRAL CONTROL UNIT
    The Central Control Unit is a single assembly and
    does not contain any serviceable parts. It can be
    removed by lifting the top plastic tabs securing it
    to the back cabinet frame and sliding it towards
    the front of the washer
    Problem Solver:
  • 19 Answers
Whirlpool duet f35 error-suds error
Maybe this will help, but I'm not sure
Condition:
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Check:
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump
Check Pressure Switch
Check CCU
Dado
Sep 13, 2015 | Whirlpool Washing Machines
My washer stops and suds flash on the display
Sud: Suds lock (overdose of detergent detected during wash cycle)
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
Possible causes/procedure:
If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
Use your tech sheet for diagnostics it is behind that panel the Handy Hippy showed you how to take loose (see above link) Use this MANUAL for Duet sport as a guide for repairs
Thanks for using fixYa
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why do I get a sud code flashing? I use only HE detergent and still have a problem.
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.Check the drain hose and make sure it is not plugged or kinked.
Check Drain Pump Check Pressure Switch Check CCU
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer (whirlpool duet) seems to cancel in the middle of load cycle. Most often the word "suds" is displayed. It is not the amount of detergent or the type because I use very little High Efficiency...
ERROR CODES
DISPLAY EXPLANATION AND RECOMMENDED PROCEDURE
Suds
6 - 7
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the
excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES THE CODE MEAN WHEN IT SAYS SUD
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Thank You
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We keep getting a "suds" code and then an F35 code
? If too much detergent was used: —Run the unit through a Rinse/Spin cycle. —Run a Normal cycle without adding any detergent. This should clear the unit of the excess detergent. 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU). 4. Check/clean drain pump filter of foreign objects. 5. Plug in washer or reconnect power. 6. Check drain pump. 7. Check the pressure switch. 8. Verify CCU operation by running a Diagnostic test or any cycle.
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool error SUB
To fix this problem do the following:
  • Check Drain Pump
  • Check CCU
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer will not spin water out
Hello, The most common cause of the 'sud' alarm is too much detergent, or the detergent that is being used is creating too much suds. It works and alarms off of the motor current draw. The causes and cures listed below are pretty much in order of their commonality; try the first item before the second one, etc. If you can pin the fault on the detergent, try using the least amount of detergent that you can while still getting your clothes clean. With a HE washer, more isn't always better. Read on:
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check CCU
Replace failed component.
Hope that this helps. Try the empty loads first to clear the detergent. This is the easiest fix.
Best regards, --W/D--
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
or kinked.
cycle.
Feb 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine stopped and says "sud"
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • Check Drain Pump
  • Check CCU
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
48 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
