Onkyo a-rv410 amplifier output problem
Buying an Onkyo a-rv410 amp. Current owner says that the output seems low after a quick test. Unit has been sitting (dry and safe) for 2 years. Owner states it is similar to when the loudness button would be off - just not as strong.
Something internal, or a button switched on or off?
  • 1,512 Answers
Hi pm, Hard to make an assertion without firing it up yourself. It may be that be has faulty speakers, speakers out of phase, faulty earthing of line out from the source he tested it with.
Good chance that it is ok. Take advantage of his concerns, and buy it extra cheap. Good luck
regards
Graeme
Posted on Mar 08, 2008
Onkyo DX-C390 with Denon AVR-S710W? This doesn't seem to work when input to the amplifier's media player audio inputs. Do I need a preamp?
Both of the devices have optical connections, by getting a lead between the two you should hear the high quality sound from the unit. Make certain the optical connection is switched on and assigned to the Onkyo.
Only a record player requires a pre-amp. If it the amp doesn't have a dedicated socket for it.
Jul 04, 2017 | Denon Audio Players & Recorders
I'm using an onkyo tx-nr609, I have a wireless speaker adaptor plugged into zone 2 on the back next to where the subwoofer plugs in, but can't seem to get any sound to come out of it. Any ideas?
Hi Chris, not all sources will play to zone 2. Only internal and analog sources. If you want to play your cable box for example you need an analog connection from the cable box to the receiver. Also, the output is very low it needs to be amplified. Thank you, Onkyo USA
Nov 15, 2016 | Onkyo Audio Players & Recorders
Onkyo amplifier power transformer voltage details
First of all, did you test the primary and secondary leads for resistance? They all should be from 2-30 ohms max. If they are, the transformer is fine. If they are open, you will need a service manual which may be on-line. If you need more assistance or would like to inquire about repairing your unit, please visit my website at audoserviceclinic.com. Thank you.
Aug 27, 2014 | Audio Players & Recorders
Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
May 24, 2010 | Onkyo M-282 2-Channel Amplifier
Onkyo tx-sr601 bi wire with zone 2
SMCCARTY,
The idea behind bi-wiring speakers is to get the highest quality of sound by getting the sound from two separate sources doing separate jobs. Lower frequencies are harder for an amplifier to produce than higher frequencies. So it is common to give these frequencies to two different amplifiers so each can produce the highest quality of sound. By removing the low end from the top end amplifier, it provides the top end amp more headroom thus reducing the chances of clipping. Clipping can easily be heard from the tweeters destoying not only the sound but your speakers as well. It is common practice in pro and car audio to use separate amps for subbass, low, mid and high; four amps working together to their corresponding drivers (more or less depending on the system and type of audio being produced).
In your case, getting the two different sources from basically the same amp (power supply), would not accomplish the full intent of bi-wiring; it would just make more wiring for the same end result. However still a good thought on your end. Onkyo receivers are great because of their beefy power supplies. Not very many other brands have such strong power supplies. Denon's are close but not equal.
Chris-
Feb 14, 2010 | Onkyo TX-SR601 Receiver
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
I have an ONKYO TX-SV717Pro amp. recently I lost
It could be that you lost the power supply to the surround amp IC or the Ic is defective. It should be mounted on a circuit board attached to the heatsink. Look for poor solder connections first. I don't recall the specifics of this model, but the surround amp IC should be easily located.
Update this with your progress and I'll try to locate the service manual in the meantime.
Dan
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
ONKYO M282 AMP seems to have lost all mid and low range
It's probably salvagable but I doubt it will be cheap or easy. Most likely you have one or more ruined output transistors. If you're into taking things apart and soldering, it might be easy for you. Just look
for abnormalities on the transistors, usually a little hole in the center of them or blistering. Replace those and you'll either have it back to sounding good or much closer to it. Most output transistors do not fail without showing visual evidence of it.
Nov 17, 2008 | Onkyo M-282 2-Channel Amplifier
Muted Sound
What is the signal level at the tape-out jacks? Is that level "normal"?
Dan
Mar 17, 2008 | Onkyo TX-DS838 Receiver
257 people viewed this question
 Grubhead
Grubhead
