Question about Freezers
Samsung refrigerator sr- l3928-b
Main relay board replaced, fridge work for 1 hour.
and decided not come on. does the parameters need setting up?
samsung not willing to send me service manual, please help,as fridge is
good condition.
2 Suggested Answers
SOURCE: flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Posted on Jan 21, 2010
I want to remove the freezer tray from SR-2570M. Can this be done without removing the refrigerant?
No. The freezer "tray" is the evaporator, and therefore, the most important part of the unit. (this applies to most mini-fridges out there)
Mar 23, 2016 | Sanyo Sr-2570M Refrigerators & Freezers
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
Nov 17, 2014 | Samsung Freezers
Why has my freezer--including the automatic ice maker, on a Kenmore Elite side-by-side fridge, suddenly shut down?
Hello Sherry;
1.) If the refrigerator shut down for 20-30 minutes:
Your refrigerator goes into a defrost cycle every 8-10 hours. The refrigerator shuts down for 20-30 minutes. At this time, you have a heater under your freezer cooling coils (Evaporator). The heater turns on and melts the frost off your cooling coils. Then the refrigerator turns back on. This is where you get the term; "Frost Free".
2.) If your refrigerator has shut down and is still shut down:
a.) If it shut down going into defrost - Some refrigerators have mechanical/electrical defrost timers that are easy to access and manually bring it out of defrost. Unfortunately, your refrigerator defrost cycle is built into your main control board.
b.) You main control board is bad. This is a primary electrical part. It is not a uncommon failure. The control board is about $85.00 and easily replaced.
I have faith in you Sherry, lets replace it:
1.) The new control board will come in a silver bag. This is a anti-static bag. Static electricity will not the board out. Ground your self by rubbing your hands on a steel object.
Move the refrigerator out to where you can freely stand behind it. Unplug the refrigerator. There is a metal cover plate about 10" x 12" on the back. Remove the screws and lift up. There are tabs on the bottom of this cover. Now, the control board in front of you is held in place by small white retaining pins. On each side of the pin is a small leg. With one hand squeeze these legs and the other hand pull the control board toward you to free the board from the leg. There are several pins around the board. Now that the board is free, take the new board, systematically going around the board one connector at a time. Remove one connector from the old board and connect it to the new board. Repeat this one connector at a time. Each connector at the top has a clip that you must squeeze to disconnect. Make sure on the new board you hear the connector click. Do not pull on the wires. The connectors are fool proof. The connectors are designed to only fit one connection size. Remount the board on the pins. put back cover on and plug in.
Nov 09, 2014 | Kenmore Elite Side By Side Refrigerator -...
How do you get compressor running after power outage?
Hello AnnArborMom, thank you for your inquiry!
I would recommend you adjusting the temperature to a lower setting to see if that would start your compressor to cool. If that is not successful I would contact a professional to come and properly diagnose your appliance. It could be that the power outage shorted the main control board or relay. I hope this is helpful. -Matt
Sep 07, 2014 | Frigidaire FGHF2366PF Gallery 22.6 Cu. Ft....
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
Samsung refrigerator not cooling
Sounds more like compressor failing to pump than board fault
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
We have a Kenmore Elite Freezer Model #253.29082994. We had the freezer plugged in and it was working fine. We unplugged it and moved it and now when we plug it in it won't start. Is there some kind of...
You refrigerator was made by Frigidaire Adaptive Defrost Controls Frigidaire Refrigerator Trouble Shooting and Diagnosing
On the initial plugin, or when power is restored to the fridge after a power outage:
If terminating thermostat is open, the fridge enters a compressor (cooling) cycle.
If the terminating thermostat is closed, the first defrost cycle occurs 1 hour
after initial plug-in.
Maximum defrost cycle time is 24 minutes.
Minimum time between defrost cycles is 6 hours. (compressor runtime)
Maximum normal clock time between defrost cycles is 12 hours.
Maximum time between defrost cycles (in "vacation" mode) is 72 hours.
Vacation mode is not entered unless the door has not been opened in at least 24 hours.
Note that the ADC will only enter the defrost mode if the terminating thermostat is closed. If the terminating thermostat is open when defrost is initiated, the ADC board will wait for six minutes and then return to the cooling mode.
ASSUMING that the fridge has been on and running,
and the terminating thermostat is closed,
defrost is initiated by pressing the door (light) switch
at least five times within six seconds.
The defrost heater should start heating up within 8 seconds.
If the above procedure caused the heater to heat up, the ADC board is probably bad; replace it.
If the defrost heater does not heat up, test the defrost heater, terminating thermostat and cold control for continuity as follows:
Unplug the fridge from the wall. Unplug the ADC board from its connector.
Test the connector for continuity between the following leads:
Defrost Heater = DEF TERM (blue) to DEF OUT (brown).
Terminating Thermostat = DEF TERM (blue) to NEUTRAL (lt blue).
Cold Control = COLD CONTROL (orange) to L1 (black).
Replace the defective component.
dvfxnxxsllnll3xsyszyldhiovfnqznnvujbtluyw2q4uxl2ntjkcdj6njhpmxnefkntwws4bi9kdg83ay5nd0jdsnhpljetrth0supsduvxugpczlkyaszhzu1onu9xwdfjv0xta0jidtfiwg%3d%3d
Apr 26, 2011 | Kenmore Freezers
Sanyo Frost Free Fridge (Model SR 1031) very slow to cycle through freeze to defrost back to freeze cycle. The temp in Freezer compartment goes from -17 degrees to -1 degree then back to -17 as it takes in...
DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
Feb 10, 2010 | Freezers
Flashing freezer temp on Samsung SR S22
Mar 25, 2009 | Freezers
Freezers Logo
48 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
