Question about Kenwood KDC-7090R
Flip bit not working KDC-7090R
Hi my cd player has stopped flipping open and wont close, it's stuck half way, although radio works but you cant change anything only the volume, cd will work if you take the face off then put back on, but again only volume will work, any ideas what it may be, ribbon was changed about a year ago
Thanks
Linda
  • lindie1 Feb 27, 2008
    Thanks, had a look but they dont do repair kit for a 7090r
  • 199 Answers
Hi its going to be the flexi that connects the panel to the main pcb. you can buy a repair kit @ www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 27, 2008
  • Mark Waller
    Mark Waller Feb 27, 2008
    same as 7080
    Mark
MY in dash dvd player with flip open screen doesn't open
in dash flip tv dosent come allthe way out
Oct 29, 2009 | Car Audio & Video
DEH-P9600MP front flip half opens and switches system off.
I also had this problem and the solution was to change the data bus, or if you want, you can pull out a little the data bus.
Mar 14, 2009 | Pioneer Premier DEH-P960MP CD Player
Not working
send it to Merle radio co., 840 south ave. ,Plainfield, NJ., 07062
phone# 908-756-3544
Apr 06, 2008 | Kenwood KDC-7090R
Kenwood kdc-x859 just stopped working
This hapened to me also. I removed the power fuse to the radio and it reset itself.
This solved the problem for me.
Feb 28, 2008 | Kenwood KDC-X859 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
Kenwood kdc-x869
Alot, of the radios have a common problem with the connection from the radio's detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, and the display partially turning on and off.
Dec 15, 2007 | Kenwood eXcelon KDC-X879 CD Player
Kenwood KDC-519 CD Player
Check ribbon cable from main board to face for breaks in the lines. Replace ribbon cable if bad.
Aug 01, 2007 | Kenwood KDC-519 CD Player
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
My head unit is awkward.
Check the wire braid going out to the faceplate. Although this is a fancy feature. it is very problematic. But usually it looks like a flat plastic strip with brown stipes on it. Sony calls it a flexible circuit board. after so many flips wires break the buttons stop working and when the face gets just is the right place it stops turning. but is repairable if you can order the braid from Kenwood about a skill level five to put in.
Sep 07, 2006 | Kenwood KDC-519 CD Player
Kenwood KDC-7090R Logo
221 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
