E-Machines T5048 (7136) PC Desktop Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The monitor isn't working on t5048 all I get is the monitor is working
Anonymous
Level 2:
  • Expert 90 Answers
  • Posted on Feb 17, 2010
Anonymous
Expert
Level 2:
Answers
90
Questions
Helped
30326
Points
195
Can you tell me more about the computer. Does it display anything at all?
sudarshan chavan
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
sudarshan chavan
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1283
Points
11
It is the problem of resolution use higher graphic end monitor lower down to the resolution like 1024x786 pixels and then connect it to your T5048 (7136) PC Desktop computer
No signal to moniter emachine t5048
DID YOU TRY A DIFFERENT MONITOR TO SEE IF THATS IT OR IT THE COMPUTER. SETTING COUSE THAT PROBLEM TO. THIS MAY HELP.
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
1helpful
Added 2 1GB memory to a T5048. Will not boot. do I need to upgrade the BIOS? Also want to disable on-board graphics and add a pci graphic card.
There are two variants of the T5048 One uses DDR PC3200 ram the other uses DDR2 PC5300
Should be able to look at the old ram and it should say on it what it is. If it doesn't, take out the new, put in the old ram and go here http://www.crucial.com/store/drammemory.aspx Run the "Scan My Computer"
Some computers will have a setting in BIOS to disable on board video although eMachine are very low end and probably don't offer that. Shouldn't need to just install your video card and plug your monitor into it. It should work just fine without disabling on board.
Comment if you need more help
2answers
What type of ram do i need to use?
Your eMachines T5048 PC Desktop uses RAM of specification DDR400 which is also called PC3200. DDR Stands for Double Data Rate.
Your computer is expandable to a maximum of 2GB
Take care!
damnor01
1helpful
My monitor isn't working. I tried a different monitor, keyboard, mouse power plug on monitor. What else it there to do. When I had another monitor attached it it had no signal on the monitor. I know the...
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
How to put the recovery partition back on the emachines t5048
As far as i know the only way is to run the restore disk from emachine that is for your model computer. (it usually wipes the computers hard disk in the process.)
the link below will take you to their support site for drivers.
on that site look for eMachines Recovery Media Purchase Program and you can see about ordering the recovery disk that you need.
http://www.e4me.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
My sound card is not installed on my computer because i did the recovery. where can i download one? it's a eMachines windows XP T Series T5048
Here's a link to the Emachine support page for your model. Scroll down to audio section and you should be able to download your sound drivers. If the sound still doesn't work after doing this download the chipset drivers and then try downloading the audio drivers again. Sometimes you need the chipset drivers first before the audio drivers will work. http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
3helpful
I have a emachine 4010. Monitor display sideways
hold alt+ctrl then click the up arrow while holding alt+ ctrl
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
