Question about Maytag MSD2756GES Side by Side Refrigerator
Maytag side by side ref. not defrosting
I have jumped the defrost board to put it into test and it will not go into defrost. I guess I just wanted another opinion before I purchase another defrost board.
  • frozen solid Mar 15, 2008
    My refrigerator MSD2756GES does not defrost, it forms a solid block of snow / ice over the evaporator and I have to thaw it with a hair dryer. Where is the auto defrost controller and can it be manually set so I can see if the function can at least work? What might I have to replace and how do I check?
    Thank you.
    President:
  • Maytag Master
  • 2,651 Answers
If it didnt go into defrost by jumping across board, i ck that with unit running compreesor on, jumping across the test leads for a few secs. if doenst shut down compressor bad board
Posted on Mar 03, 2008
I have a Maytag MZD2766GEW ref/freezer that the freezer works, but the fridge is warm. I removed the back panels and the coils were all froze over. I am trying to test the Defrost Control Board. How do I...
in most cases its not the defrost board test the defrost element/s make sure they are not blown test at both ends like a fuse you should get a resistence rating of around .2 ohm if the curcuit is open then the defrost elements need replacing maytag have very reliable defrost control boards they dont fail all that often
best of luck
please take the time to rank my reply
Dec 01, 2010 | Whirlpool Refrigerators
I have a maytag plus model #msd2758drb, the freezer builds up with ice really quick,then the frigerator warms up want can i do?
You have a problem with your defrost system. The defrost heater is not coming on to thaw the frost that builds up on your evaporator coils. This restricts the airflow to the ref side. You will need to find out which component needs to be replaced it could be your defrost control, defrost thermostat, or defrost heater. The heater and thermostat are located behind the freezer panel. The heater can be ohmed out with a meter and tested for continuity, the thermostat will usually be popped out if its bad. If both of these parts are good then the problem is your defrost control, my model look-up is down right now but it could be a circuit board or just a standard "timer" style control.
Hope this helps _MJ_
Feb 07, 2010 | Refrigerators
Maytag MSD2556AEW coils are freezing
you may want to replace the defrost thermo as it is most common / the defrost heater is probably ok / then the ADC / hope this helps .. ****
Jan 17, 2010 | Maytag MZD2766GES Side by Side...
I have a maytag s/s refride/freeze MZD2766ge Evap coil ices up no cooling to fridgIm preety sur its theheater/thermo. But imconcerned it could be a defrost board involved but im not sure
Good day,
the board in this machine is notorious for failing. Testing by jumping L1 to test terminal may tell you, but other components in the board may give you a false response.
The main heater rarely fails and you can test it with an ohm meter to verify that.
If the main heater checks good for continuity, replace the defrost thermostat, and board. Best long term repair.
Nov 05, 2009 | Maytag MZD2766GES Side by Side...
Maytag plus refrigerater not cold enough
If the freezer is cold and the refrigerator is warm, the unit is probably not going into defrost. Remove the back inside of the freezer and see if all frosted up. If so thaw with a hair dryer and replace the adaptive defrost assembly located inside the back of the refrigerator section. Up on the ceiling of the ref where you adjust the temp. remove thc cover by putting your fingers in the back holes and pull forward. Make sure the ref is unplugged. Remove two 1/4" head screws in the front and two phillip head screws by the lights. One 1/4" head screw straight in the back. The defrost timer is located in the far right corner. A small board 2 to 3" square. It will unplug and is probably screwed in.
Sep 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frig side not working on Maytag MZD2766GEW
freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
May 23, 2009 | Maytag MZD2766GES Side by Side...
MAYTAG MSD2656DEB DEFROST CONTROL
There is no forced defrost entry for your refrig. Yours has a ADC board in the upper right corner of the control area in the refrig section. The only way to initate defrost is jump the terminals on the board. Look at the wiring diagram closely before making the jump. The board energizes the heater thru the neutral side so make sure you dont jump line to this. I believe you jump L2 to Def
Dec 02, 2007 | Refrigerators
Maytag MSD2356 Freezer frosts up quickly, fridge warm
If you jumped the defrost board and it went into defrost then that board is bad. I assume by "freezes up" you are talking about the evaporator is frosting up? That defrost board puts it into defrost automatically. If you have to jump it to get it go into defrost then the board is not doing its job.
Nov 16, 2007 | Maytag 23 cu. ft. Side-by-Side...
Defroster problems
tduck, what the tech was refering to is the adaptive defrost board. This is a common failure on these models. You are going to find it in the refrigerator side. Remove the temp control end knobs from the controllers. Remove the screws holding the light shield. Now in the back on each side you will see a tab that pushes in and the cover will pull straight out. This sometimes can be difficult task, those tabs are a real pain. Now you will remove the screws holding the defrost timer cover and the defrost timer will be in the back on the right side. On this defrost board you will see L1 and test right next to eachother. Using a small screw driver short across these terminals with the harness on. This will put the refrigerator into the defrost. If it goes into defrost and jumps right back out, you know it's the defrost board. The defrost bi-metal will be normally closed and open to terminate the defrost. So if your evaporator is warm, it will not go into defrost. You should be able to get a breakdown of this at Sears.com, go to appliance parts and enter your model number. Usually the adaptive defrost board is the culprit, I don't see too many heaters or bi-metals (defrost terminators) go bad. Your part number for the board is 61003990 for series 10. See if your serial number starts with 10.....Catriver..post back.
Dec 23, 2006 | Maytag MSD2756GES Side by Side...
Maytag MSD2756GES Side by Side Refrigerator Logo
180 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
