Question about Vivitar ViviCam 5385 Digital Camera
Vivitar 5385 digital camera
When I zoom in I can only get half way then the camera shuts down. All other functions appear fine.
  • ritadantas May 18, 2008
    I have absolutely the same problem, the camera zooms halfway and then shuts down, all other functions work perfectly. Please somebody let me know should there be a solution.
  • Brinna Jun 17, 2008
    I was having the same problem. now my camera turns on says lens error then turns off
Mine was doing this and now it won't even turn on. It turns on, says lens error, then turns off.
Posted on Jun 17, 2008
SOURCE:
Camera shuts down when i use the zoom.easy share c180
Using the zoom requires the motor which pulls more power than the camera when idle. If the battery is close to exhausted it will shut the camera off when you zoom. If this isn't the case your zoom may be stuck and the camera shuts down to prevent damage.
Oct 13, 2014 | Kodak EasyShare C180 Digital Camera
My zoom is not working properly.. shuts itself off
Never leave battery in the camera, it gives out fumes that can ruin electronic circuits. You may have to replace the motherboard.
Feb 14, 2012 | Olympus FE-280 Digital Camera
ERREUR ZOOM
have experienced the exact same problem that you have described. The lens is stuck in a zoom position and I am receiving a zoom error, it needs to be taken apart by local electroinic shop
Apr 25, 2011 | Vivitar ViviCam 5385 Digital Camera
How do I change the date on my ViviCam 5385 digital camera?
Assuming the camera is working, with the camera off, rotate the mode dial so that the icon with the wrench lines up as the active mode. Then press the Power button and turn on the camera. Press the right arrow to select Custom Menu. Then press the down arrow to select Date and Time. Then press the OK button. Use the left and right arrows to select a part of the date to change and use the up arrow to increase the value and slide the zoom lever to down button to decrease the value.Press the OK button when the date and time (24 hour clock) is properly set.
The manual for the 5385 is available at retrevo: http://www.retrevo.com/support/Vivitar-5385-Digital-Cameras-manual/id/200bh836/t/2/ . You'll need to enter a code to access the PDF.
I hope this helps.
Mar 06, 2011 | Vivitar ViviCam 5385 Digital Camera
When I turn on my vivicam 5385 the lense goes in and the shutters close. When i turn it off, the lense goes partially out and the shutters open. The zoom function doesnt work either. Any suggestions??
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Vivitar ViviCam 5385 Digital Camera
Vivicam 5385 wont zoom in or out, shuts off when i try
It sounds like the motor and gear assembly for the zoom is jammed. Your camera processor detects the problem and shuts the camera off in order to protect it from further damage. I would suggest you take it in for repair at an authorized digital camera repair shop. A qualified technician then can further assess the problem and give you some advise as to what would be the best solution for you.
I hope this helps you out. Good Luck.
Nov 12, 2009 | Vivitar ViviCam 5385 Digital Camera
May i know the service centers for vivitar digital camera in hyderabad..
sorry there is no service centers in hyderabad for vivitar digital camera....
Nov 10, 2009 | Vivitar ViviCam 5385 Digital Camera
I switch the camera on. I get 3 beeps and it shuts down.
The problem is of zoom lens motor which operates lens cover along with zoom, and it needs replacement with new part, and camera will start working fine again.
Thanks for using fixya
Jul 26, 2009 | Samsung Digimax S600 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
52 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
